problem with some mp4 files
Posted: Tue Jun 08, 2010 10:18 am
i have a problem with some mp4 files. Most of my mp4 files are working without any problems.
But i bought a new camera (Sony Cybershot DSC-WX1) and all these mp4 movies are not added to the index??
THX!!
Ben
Here some media infos:
Complete name : G:\movie\test\test.mp4
Format : MPEG-4
Format profile : Sony PSP
Codec ID : MSNV
File size : 35,9 MiB
Duration : 34s 34ms
Overall bit rate : 8 849 Kbps
Encoded date : UTC 2010-05-31 20:00:24
Tagged date : UTC 2010-05-31 20:00:58
Video
Format : MPEG-4 Visual
Format profile : Advanced Coding Efficiency@L4
Format settings, BVOP : YES
Format settings, QPel : no
Format settings, GMC : no warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 34s 34ms
Bit rate mode : variabel
Bit rate : 8 782 Kbps
Nominal bit rate : 9 000 Kbps
Maximum bit rate : 14,0 Mbps
Width : 1 280 Pixel
Height : 720 Pixel
Display aspect ratio : 16:9
Frame rate mode : konstant
Frame rate : 29,970 FPS
Resolution : 8 bits
Scan type : progressiv
Bits/(Pixel*Frame) : 0.318
Stream size : 35,6 MiB (99%)
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings, SBR : YES
Format settings, PS : YES
Codec ID : 40
Duration : 34s 5ms
Bit rate mode : konstant
Bit rate : 64,0 Kbps
Channel(s) : 2 Kanäle
Channel positions : Front: L R
Sampling rate : 48,0 KHz
Stream size : 266 KiB (1%)
THX!!
Ben
Format : MPEG-4
Codec ID : MSNV
Duration : 34s 34ms
Video
Codec ID : 20
Duration : 34s 34ms
Width : 1 280 Pixel
Height : 720 Pixel
Resolution : 8 bits
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 34s 5ms
