Error number -1 occured in transcoding
Posted: Mon May 24, 2010 10:29 pm
by copson
I have encountered an error using 1.00 when trying to transcode a mkv to my Samsung B650. The log is below. I copied the mkv to an external USB disk and managed to watch it on my TV so nothing seems to be wrong to the mkv itself, but something seems to make WMS to fail to transcode it.
"C:\Program Files\Wild Media Server\wmsmpeg.exe" -i "Z:\Video\test.mkv" -f mpegt
s -vcodec mpeg2video -b 20000000 -minrate 20000000 -maxrate 20000000 -bufsize 3
047424 -aspect 16:9 -copyts -pix_fmt yuv420p -s 1280x720 -vhook "wmssubt.dll Z:\
Video\test.mkv,Verdana,14,1,16777215,0,4,0,0,0,1280,720,23.976,0,0,0,[0x3],0,1"
-vhook "wmssubt.dll indicator,Verdana,14,1,16777215,0,4,1677721600,1280,720,35,4
,7" -threads 4 -acodec copy -map 0:0 -map 0:1 "F:\Transcode\WmsTemp\Test_fdbb388
50e57b311adec34366c712a8b.mpg" -v -1 -loglevel quiet
built on May 2 2010 17:40:51 with gcc 4.4.0
libavutil 50.13. 0 / 50.13. 0
libavcodec 52.61. 0 / 52.61. 0
libavformat 52.57. 1 / 52.57. 1
libswscale 0.10. 0 / 0.10. 0
[matroska @ 003ca290]max_analyze_duration reached
[matroska @ 003ca290]Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (200000
00/417083) -> 23.98 (24000/1001)
Input #0, matroska, from 'Z:\Video\test.mkv':
Duration: 02:13:51.07, start: 0.000000, bitrate: N/A
Stream #0.0: Video: h264, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 47.62 fps, 2
3.98 tbr, 1k tbn, 47.95 tbc
Metadata:
title : By CMCT-hanksking
Stream #0.1(eng): Audio: ac3, 48000 Hz, 6 channels, s16
Stream #0.2: Subtitle: 0x0000
Metadata:
title : Þï▒õ©èõ©¡õ©ï
Stream #0.3: Subtitle: 0x0000
Metadata:
title : õ©¡õ©èÞï▒õ©ï
Stream #0.4: Subtitle: 0x0000
Metadata:
title : õ©¡µûç
Stream #0.5: Subtitle: 0x0000
Metadata:
title : Þï▒µûç
[matroska @ 025de160]max_analyze_duration reached
[matroska @ 025de160]Estimating duration from bitrate, this may be inaccurate
Output #0, mpegts, to 'F:\Transcode\WmsTemp\Test_fdbb38850e57b311adec34366c712a8
b.mpg':
: Video: mpeg2video, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], q=2-31, 20000 kb/s, 9
0k tbn, 23.98 tbc
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Press [q] to stop encoding
av_interleaved_write_frame(): Error number -1 occurred
Re: Error number -1 occured in transcoding
Posted: Tue May 25, 2010 6:28 am
copson wrote:I have encountered an error using 1.00 when trying to transcode a mkv to my Samsung B650. The log is below. I copied the mkv to an external USB disk and managed to watch it on my TV so nothing seems to be wrong to the mkv itself, but something seems to make WMS to fail to transcode it.
Metadata:
Metadata:
Metadata:
Metadata:
title : õ©¡µûç
Metadata:
title : Þï▒µûç
b.mpg':
0k tbn, 23.98 tbc
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Settings-Transcoder-"Codecs, frame" - turn off "The original sound track, if the compression is the same".
Posted: Tue May 25, 2010 6:45 am
by copson
Thanks, it worked perfect after turning that setting off!
