Transcode MKV AC3 and maintain 5.1
ric9887
Post by ric9887 »
What setting do I need to use to transcode a MKV with an AC3 5.1 soundtrace to a 360 and maintain 5.1 audio, and is it possible to transcode an MKV with DTS and maintain the 6 channels.
I can transcode MKV files which have AC3 5.1 soundtrack, but I only get a 2.0 soundtrack on the 360.
Regards
Rich
Re: Transcode MKV AC3 and maintain 5.1
ric9887 wrote:What setting do I need to use to transcode a MKV with an AC3 5.1 soundtrace to a 360 and maintain 5.1 audio, and is it possible to transcode an MKV with DTS and maintain the 6 channels.
Transcoding profile "Movies - DirectShow - WMV" (chose on right click mouse "Transcoding profile"), but I checked his work now, there are problems.
Try this fix
Settings-Transcoder-Profiles-"Movies - DirectShow - WMV"-Edit-find
  if (WmsDirectShowAddFilter('PCM', 'Audio Decoder', '{33D9A761-90C8-11d0-BD43-00A0C911CE86}') <> S_OK) or
     (WmsDirectShowConnectPin('Source', 'Audio Decoder', '', '', MEDIATYPE_Audio) <> S_OK) or
     (WmsDirectShowConnectPin('Audio Decoder', 'Audio Encoder', '', '') <> S_OK) then begin
    WmsDirectShowRemoveFilter('Audio Decoder');
    if not CheckResult(WmsDirectShowAddFilter('ffdshow Audio Decoder', 'Audio Decoder')) then
      Exit;
    if not CheckResult(WmsDirectShowConnectPin('Source', 'Audio Decoder', '', '', MEDIATYPE_Audio)) then
      Exit;
    if not CheckResult(WmsDirectShowConnectPin('Audio Decoder', 'Audio Encoder', '', '')) then
      Exit;
replace on
    Exit;
    Exit;
    Exit;
