GPU transcode?
Posted: Fri May 07, 2010 6:49 am
by boeonoz
Can it use GPU to transcode? I have ATI 5800 series, it can easily transcode 1080p video.
But Wild server always use CPU to transcode with my Q6600, it cannot transcode 1080p. It barely reach 21 fps and always have to stop during watching.
Re: GPU transcode?
Posted: Sat May 08, 2010 6:33 am
boeonoz wrote:Can it use GPU to transcode? I have ATI 5800 series, it can easily transcode 1080p video.
ATI codecs are slower FFMPEG
Re: GPU transcode?
Posted: Fri Jun 11, 2010 3:32 am
by boeonoz
you are wrong!!
If compare Q6600 CPU transcode and ATI 5850 GPU Video transcode.
ATI have internal hardware based H.264/VC-1 decoding sure it must be faster if WMS transcode to it.
Re: GPU transcode?
Posted: Fri Jun 11, 2010 9:17 am
boeonoz wrote:you are wrong!!
You can try ATI software for transcode to 1920x1080 frame size.
Re: GPU transcode?
Posted: Fri Jun 18, 2010 10:52 pm
by grolschie
The new release candidate of VLC lists "GPU and DSP decoding, depending on the platform" as a new feature:
http://www.videolan.org/vlc/releases/1.1.0-RC.html
EDIT: I installed it, but I don't think WMS 1.0.3 works with VLC 1.1.0-RC presenty. I have uninstalled VLC 1.1.0-RC and will reinstall VLC 1.0.5 for now.
Re: GPU transcode?
Posted: Sat Jun 19, 2010 4:34 am
grolschie wrote:The new release candidate of VLC lists "GPU and DSP decoding, depending on the platform" as a new feature:
Thanks for info, I will check http://www.videolan.org/vlc/releases/1.1.0-RC.html
There are examples of problematic links ?
Re: GPU transcode?
Posted: Sat Jun 19, 2010 5:11 am
by grolschie
Hi there. I couldn't play any internet tv or radio links that used the new VLC for some reason. I tried a normal mp3 radio stream which was fine, another wasn't though. Using vlc to transcode .m4a files into .mp3 was ok.
Re: GPU transcode?
Posted: Sat Jun 19, 2010 9:04 am
Temporary fix: Settings-Transcoder-Profiles-"Internet-television"-Edit:
Transcoder: VLC
Transcoding parameters:
function GetAudioCodec(const aFileFormat: string): string;
  if SameText(aFileFormat, 'ASF (Windows Media Format)') then
    Result := 'wma2'
  else
    Result := 'mpga'
function GetFileFormat(const aFileFormat: string): string;
    Result := 'asf'
  else if SameText(aFileFormat, 'MPEGTS (MPEG Transport Stream)') then
    Result := 'ts'
  else if Pos('SONY', UpperCase(cfgDeviceType)) > 0 then
    Result := 'ps'
  else
    Result := 'mpeg1'
function GetVideoCodec(const aFileFormat: string): string;
    Result := 'wmv2'
  else
    Result := 'mp2v'
  csVideoLanParams =
    '-Idummy --language=en --sout=#transcode' +
    '{vcodec=%s,vb=%d,fps=%s,scale=1%s,acodec=%s,ab=%d,channels=2,' +
    ' "<INPUT FILE>"'; //  vlc:quit
  i, iWidth, iHeight, iAspectWidth, iAspectHeight: Integer;
  sCanvasParams, sFrameRate, sDeinterlace: string;
  if WmsGetVideoSettings(vstDeinterlace) = 'on' then
    sDeinterlace := ',deinterlace'
  else
    sDeinterlace := '';
  if mpInternetItem then
    sFrameRate := '24'
  else if cfgTranscodingFrameRate <> '' then
    sFrameRate := cfgTranscodingFrameRate
  else if mpFrameRate > 0 then
    sFrameRate := FormatFloat('0.000', mpFrameRate)
  else
    sFrameRate := '25';
  if SameFloat(sFrameRate, '23.976') then
    sFrameRate := '24'
  else if SameFloat(sFrameRate, '29.970') then
    sFrameRate := '30'
  else if SameFloat(sFrameRate, '59.940') then
    sFrameRate := '60';
  iWidth := mpWidth;
  if iWidth > 0 then begin
    i := Pos(':', cfgTranscodingScreenFormat);
    if i > 0 then begin
      iAspectWidth  := StrToIntDef(Copy(cfgTranscodingScreenFormat, 1, i - 1), 16);
      iAspectHeight := StrToIntDef(Copy(cfgTranscodingScreenFormat, i + 1, 10), 9);
    end else begin
      iAspectWidth  := 16;
      iAspectHeight := 9
    if iWidth > cfgTranscodingScreenWidth then
      iWidth := cfgTranscodingScreenWidth;
    if iWidth > 1280 then
      iWidth := 1280;
    iHeight := Round((iWidth / iAspectWidth) * iAspectHeight);
    if iHeight mod 2 <> 0 then
      Inc(iHeight);
    sCanvasParams := Format(',vfilter={canvas{width=%d,height=%d,aspect=%s}}', [iWidth, iHeight, cfgTranscodingScreenFormat]);
  end else
    sCanvasParams := '';
  TranscodingParams := Format(csVideoLanParams,
                               [GetVideoCodec(cfgTranscodingFileFormat),
                                Min(cfgTranscodingVideoBitrate div 1000, 12000), sFrameRate,
                                sCanvasParams,
                                GetAudioCodec(cfgTranscodingFileFormat),
                                Min(cfgTranscodingAudioBitrate div 1000, 192),
                                sDeinterlace, GetFileFormat(cfgTranscodingFileFormat)])
Re: GPU transcode?
Posted: Sat Jun 19, 2010 9:19 am
by grolschie
Thanks for such a quick response. I tried the code, but it did not work. The usual error about file unsupported or corrupt (or whatever it says) error when playing internet television. I am happy to revert to VLC 1.0.5. The new VLC is a release candidate, not the full release. Many thanks. :-)
