streaming on nx705
Posted: Mon May 03, 2010 6:51 pm
by aramo
at first i have to say that the wms is great, i am using it for one week and had some problems at first, but i solved them as well by reading this forum.
But today i tried to stream a movie (1080p .mkv) again, but the movie started to stutter so it was impossible to enjoy it.
after trying to change some settings and having no better results, I reinstalled wms but it didn't change anything.
Now even the movies that streamed without stuttering, stardet to lag, too. (some of them HD, .mkv , .vob)
they definately worked before!
and now the most important facts :
-The fps (in every test is higher than the native fps, often between 38 and 77), that means that the transcoding is working good, doesn't it?
-my wifi network (54Mbit/s) is only 12% used, so it can't be the reason, too.
I am now really afraid that the brand new TV has a damage in his wifi connection....how can I find that out?
(sorry for my English, I live in Germany)
Re: streaming on nx705
Posted: Tue May 04, 2010 10:41 pm
by bubblegum
I'd suspect the WiFi cannot stream HD movies. Try a direct network cable.
Or, buy Home plug, thats what I have now.
Posted: Wed May 05, 2010 10:52 am
by aramo
thanks for your reply!
i thought the same, but the taskmanager says that only 20% of the 54 Mbits are used.
Has my TV also 54Mbits bandwidth? I can't find that out.
Is it possible to connect the TV with the notebook directly or do I have to connect it via the Router?
What is "home plug" ?
Posted: Thu May 06, 2010 1:20 pm
by bubblegum
I have my TV connected to the router. I'm not sure if you need a crossover cable to go to the pc.
Posted: Fri May 07, 2010 8:42 am
by aramo
Ok since i'm using a patch cable, the streaming works again...
The only confusing thing is that it worked at the beginning via wifi and not anymore (the same movies)
@bubblegum: thx for your replies
Posted: Sat May 15, 2010 4:18 pm
by nickir
I know it hasn't any relevens. But how do you share the .mkv, when I try to tv can't find it. I have a EX500.
I am quite new on this program.
Posted: Sat May 15, 2010 7:08 pm
by bubblegum
My movies are in an external drive.
You have to change settings so it scans the folders.
Then go to Tv, Movies, Watch Folders, then "movies on your pc"
Posted: Sat May 15, 2010 8:20 pm
by nickir
Thank you. It can find them now.
