WDTV translate profile
Posted: Sat Apr 10, 2010 1:45 pm
by km123
Is it possible create '
translate profile'
Transcode is change or recode codec X to codec Y this is loosing CPU power and quality
in my meanning
translate is only use VLC/mplayer/mencoder
dump shoutcast stream and create output in suitable file format without
transcoding
example mencoder
-ovc copy -oac copy -of [mpeg or mp4] ... tml]source
when is based on ffmpeg there is acodec option also copy
is it possible use aenc=copy for this ?
Re: WDTV translate profile
Posted: Sat Apr 10, 2010 3:29 pm
translate profile'
in my meanning
transcoding
example mencoder
Settings-Transcoder-Profiles-Add
Media resource type: Music
Mime-type: video/mpegts
Transcoding parameters:
"<VLC>" -Idummy --language=en --sout=#duplicate{dst=std{access=file,mux=ts,dst="<OUTPUT FILE>"}} "<INPUT FILE>"
Choose a new profile for a media resource on the right mouse button. By default transcoding buffer for internet resources is not used (size = 0). Settings-Transcoder-Buffer-Internet
Another profile
"<VLC>" -Idummy --language en --sout=#transcode{acodec=s16le,samplerate=44100}:duplicate{dst=std{access=file,mux=wav,dst="<OUTPUT FILE>"}} "<INPUT FILE>"
Mime-type: audio/x-wav
Posted: Sat Apr 10, 2010 5:01 pm
by km123
this is not working for me now - vlc syntax is ok (Audio - remux profile)
VLC executed from cli is working but WDTVlive is not playing i-radio
only busy rotating cursor is on TV
Posted: Sat Apr 10, 2010 5:55 pm
by km123
update on 0.73.4 version
but oroginal Music VLC -> WAV is producing this error
VLC- error log
File reading failed:
VLC could not open the file "Code:".
Your input can't be opened:
VLC is unable to open the MRL 'Code:'. Check the log for details.
VLC could not open the file "E:\tmp\WmsTemp\Test_d2043da22032f15de979796021f70da4.wav".
VLC is unable to open the MRL 'E:\tmp\WmsTemp\Test_d2043da22032f15de979796021f70da4.wav'. Check the log for details.
"\Program Files\VideoLAN\VLC\vlc.exe" Code: "E:\tmp\WmsTemp\Test_d2043da22032f
"\Program Files\Wild Media Server\wmsmpeg.exe" "D:\Program Files\VLCPortable\A
pp\vlc\vlc.exe" -Idummy --language en --sout=#transcode{acodec=s16le,samplerate=
44100}:duplicate{dst=std{access=file,mux=wav,dst="E:\tmp\WmsTemp\Test_d2043da220
32f15de979796021f70da4.wav"}} "http://94.23.8.96:8030"
Posted: Sun Apr 11, 2010 6:26 pm
I have no problems at WDTV Live with profile
Perhaps you have a problem because of the use VLC Portable
Posted: Sun Apr 11, 2010 7:39 pm
by km123
no VLCportable is removed and installed normal 1.0.5 Goldeneye VLC player
I am using last fw in WDTVlive player
if is possible add to "how to use WMS" also Music documentation
what is minetype (I know what is) but how minetype affecting playback
changing filename extension or minetype is part of XML packet which is sent to player
WDTV live is not using "file/magic" filetype for detection wrong
filename extension and supported codec in supported container is sometime problem
