remote administration
Posted: Sun Mar 28, 2010 11:36 am
by utillity
Hi again,
since I'm running the server as a windows-service on a windows-2008-core machine, I would like to maintain it from my windows-7 client machine. Is this possible or will there be support for this in the future?
regards, utillity
Re: remote administration
Posted: Sun Mar 28, 2010 12:00 pm
utillity wrote: since I'm running the server as a windows-service on a windows-2008-core machine, I would like to maintain it from my windows-7 client machine. Is this possible or will there be support for this in the future?
Is not possible, and is not planned. You can used standard tools of Windows (Remote desktop connection)
Posted: Sun Mar 28, 2010 12:03 pm
by utillity
hi thanks,
where is the information (genre, titles etc) saved? I just moved some file into a sub-folder and now all information is lost. I would like to be able to specify this information within the meta-information of the file itself - then once they are on the server, that information could be used by WMS. Would this be possible? which tool would I have to use to write/update that metadata?
Posted: Sun Mar 28, 2010 12:19 pm
utillity wrote: where is the information (genre, titles etc) saved? I just moved some file into a sub-folder and now all information is lost. I would like to be able to specify this information within the meta-information of the file itself - then once they are on the server, that information could be used by WMS. Would this be possible? which tool would I have to use to write/update that metadata?
Settings-Processing-Save, load metadata... Edit - turn on "Button on the main form"
Posted: Sun Mar 28, 2010 1:17 pm
by utillity
works like a charm, thanks!
