Selecting the language of a movie to stream
Posted: Wed Mar 24, 2010 6:18 pm
by klemensl
first, wild media server seems to be a great app. I got some .mkv movies with two audio languages. Is it possible to select which language should be streamed to the tv (samsumg ps50b850)? It is possible to select a specific audio track using "Select Track" but this does not change the streamed language. It seems that always the #1 audio track is used.
thx
Re: Selecting the language of a movie to stream
Posted: Wed Mar 24, 2010 7:21 pm
If your TV does not support the choice of a audio track, it is only through the folder Transcoding. For mkv at Samsung can use the profile transcoding "Movies - TsMuxer", without changing the video, audio, if it corresponds to transcode settings, it is also unchanged.
