Startup program by starting Windows
Posted: Mon Mar 22, 2010 6:26 pm
by Victorio
This autoload feature doesnt seem to work on my 64 bit Windows 7.
I placed a shortcut (start minimized) in my startup programme's folder but that doesn't do what i hoped it to do... WMS starts with windows but the program isnt minimized.
How can I start wms (and server) automatically when Windows starts?
Re: Startup program by starting Windows
Posted: Mon Mar 22, 2010 7:17 pm
Victorio wrote:This autoload feature doesnt seem to work on my 64 bit Windows 7.
Settings-Additional (or add /hide)
Posted: Mon Mar 22, 2010 8:14 pm
by riksa
Is there a possibility regarding on this startup-topic to have an option to not show the splashscreen on startup?
Posted: Tue Mar 23, 2010 2:19 pm
riksa wrote:Is there a possibility regarding on this startup-topic to have an option to not show the splashscreen on startup?
No, this option is not. You can use the mode as a service in Windows.
Posted: Wed Mar 24, 2010 12:18 pm
by Victorio
But when I run it as a windows service my TV doesnt see the server. Like it isnt running at all.
Really too bad I can't run the program (minimzied) and start the server at windows startup.
Posted: Sun Mar 28, 2010 12:09 pm
by twol
I had the same problem running WMS as a windows service, the Panasonic TV says cannot access the server.
Running as a normal application - no problem
Otherwise great software, I continuously find new things - that also work!
Posted: Sun Mar 28, 2010 12:16 pm
viewtopic.php?f=3&t=6
If you use a firewall program, check its rules for the module wms.exe (if the server runs as a service Windows, the module wmssvc.exe),
Posted: Mon Mar 29, 2010 7:07 am
by twol
OK unblocked the service module in windows firewall and it works fine - thanks ;)
Posted: Fri Apr 02, 2010 3:53 pm
by docbells
I have both start server when program starts and start program when windows starts - and it does not work. Using Windows XP 32 bit - I have to manually start the program every time.
