WDTV Live not working
Posted: Thu Mar 18, 2010 11:42 pm
by que180
Hello everyone I am newbie at this so please be gentle. I have followed all the steps and still not able to get it play my movies. I can see all of them but when I select one for viewing the only thing it does is show the spinning circle. Like if its buffering or something but I have changed the setting for buffering. I have set the software for WDTVLive settings. All my movies are in .avi format.
Thank, Q
Re: WDTV Live not working
Posted: Sat Mar 20, 2010 1:02 am
by Dion
It sounds like its trying to transcode the movie. Do these movies have subtitles by any chance?
Posted: Sat Mar 20, 2010 6:36 am
by que180
No subtitles all the movies are english speaking films.
Posted: Sat Mar 20, 2010 7:52 pm
Playing through USB ?
Posted: Sat Mar 20, 2010 10:12 pm
by que180
yes the device works with items plugged in the usb. but i am trying to stream from over my network from my home server.
Posted: Sun Mar 21, 2010 9:14 am
que180 wrote:yes the device works with items plugged in the usb. but i am trying to stream from over my network from my home server.
Check that the file is played via USB, then check that same file is played through the server.
Posted: Mon Mar 22, 2010 11:36 pm
by 2Old4DigitalLife
Q, check your network cabling.
I had some trouble streaming the Internet to my TV. I had all CAT5 cabling.
Changed everything to CAT6, and now basically everything from the Internet streams flawlessly.
If you are using wireless, check that you have N router. G only routers do not do so good.
Mike
