Transoding profiles after update
Posted: Mon Jan 14, 2013 11:24 am
by fleggy
it is needed to restore transcoding profiles from distribution kit after an update? Or how can I check if the restoration is needed? After the last update I tried to restore Movies (additional) and the restored version is different from the previous one. But I am not sure if I ever changed this profile.
Thank you
Tomas
Re: Transoding profiles after update
Posted: Mon Jan 14, 2013 1:47 pm
fleggy wrote: it is needed to restore transcoding profiles from distribution kit after an update? Or how can I check if the restoration is needed? After the last update I tried to restore Movies (additional) and the restored version is different from the previous one. But I am not sure if I ever changed this profile.
http://www.wildmediaserver.com/forum/vi ... f=3&t=1466
Wild Media Server (UPnP, DLNA, HTTP) v.1.50
4. Updated transcoder FFMPEG (ffmpeg-1.dll), due to changes in the padding parameters (replaced by the use of a filter pad),
the existing user transcoding profiles may be required to make the changes.
