A few movies won't play on my popcorn hour.
Posted: Sun Mar 07, 2010 1:23 pm
by weaver4
I have a few mp4 movies that will not play on my popcorn hour A-100 using the WMS. But they play fine over the network.
The popcorn hour will say "buffering" for about 30 seconds and then say it cannot play.
How do I trouble-shoot a problem like this? Is there a log file.
Movies play fine on my WDTV-Live box.
Re: A few movies won't play on my popcorn hour.
Posted: Sun Mar 07, 2010 6:21 pm
weaver4 wrote:I have a few mp4 movies that will not play on my popcorn hour A-100 using the WMS. But they play fine over the network.
mp4-files are included in the list of supported devices (Settings-Device)?
Which mime-type for mp4 files in the Settings-File Types?
Posted: Sun Mar 07, 2010 6:37 pm
by weaver4
About 80% of my mp4's play fine. So it is not a setup problem.
It seems that many of my videos that I made at a specific time with Ripbot264 do not play properly with WMS but play fine when the movie is played directly on PopCornHour.
Posted: Sun Mar 07, 2010 6:56 pm
weaver4 wrote:About 80% of my mp4's play fine. So it is not a setup problem.
WMS does not play the files, he sends them, may need a different mime-type. Popcorn shows any information about media resources ?
Posted: Sun Mar 07, 2010 10:05 pm
by weaver4
I think that for some reason the WMP has decided to transcode these specific files, but not others.
But the WMP should not be transcoding these files because the PopCornHour can play them properly without transcoding.
AVI world was so much simpler....everything was H-263 and MP3 and it worked on everything.
