Page 1 of 2
Feature request: Artist & Title Index
Posted: Thu Dec 31, 2009 7:26 pm
by cgeorgakopoulos
Hi, can you add an artist index option like twonky media server? The full artist list is not convenient with a large db.
Eg:
Artist Index ->
A B C D E F ...... ->
Celine Dion - Coolio - Cyborg .... ->
Gangsters Paradise - ...
Re: Feature request: Artist & Title Index
Posted: Fri Jan 01, 2010 12:16 pm
cgeorgakopoulos wrote:Hi, can you add an artist index option like twonky media server? The full artist list is not convenient with a large db.
Eg:
Artist Index ->
May be in future versions.
Now you can create Artist Index folder Playlists:
1. Settings - Processing - Add
2. Name: Artist Index
3. Language: PascalScript
4. Expression
function GetProperty(aItem: TWmsScriptMediaItem; aPropertyID: Integer): string;
  Result := VarToStr(aItem.Properties[aPropertyID]);
  if Result = '' then
    Result := 'Unknown'
  sCollectionPath, sDirectory: string;
  sCollectionPath := 'Artist Index\' + Copy(GetProperty(aItem, mpiAuthor), 1, 1) + '\' +
                  GetProperty(aItem, mpiAuthor) + '\' + GetProperty(aItem, mpiAlbum);
  WmsDatabaseAddLink(mfAudioPlaylistsItemID, sCollectionPath, aItem);
  MediaItemList: TWmsScriptMediaItemList;
  MediaItemList := WmsCurrentMediaListItems;
  try
    if MediaItemList.Count > 0 then begin
      WmsShowProgress('Create Artist Index...');
      try
        for i := 0 to MediaItemList.Count - 1 do begin
          if WmsCancelPressed then
            Break
          else begin
            ProcessItem(MediaItemList[i]);
            WmsSetProgress(Round(((i + 1) / MediaItemList.Count) * 100))
      finally
        WmsHideProgress
        MessageDlg('Create Artist Index interrupted by the user.', mtError, mbOK, 0)
      else
        MessageDlg('Create Artist Index was successful.', mtInformation, mbOK, 0)
    end else
      MessageDlg('No files to process.', mtError, mbOK, 0)
  finally
    MediaItemList.Free
  WmsDatabaseAutoSave;
  ProcessMediaResult := True
5. Check "Button on the main form"
6. OK-OK-OK
7. Activate folder "All music"
8. Press button "Artist Index"
9. In folder "Playlists" must create Artist Index.
Posted: Fri Jan 01, 2010 12:51 pm
by cgeorgakopoulos
I love you!
I need to modified a little bit, I'll post when I'm done.
Happy new year!
Posted: Fri Jan 01, 2010 1:33 pm
by cgeorgakopoulos
I made a song index too (in basicScript, I'm a VB guy):
Function GetProperty(Item As TWmsScriptMediaItem, PropertyID As Integer) As String
	Dim PropertyValue As String = VarToStr(Item.Properties(PropertyID))
	If PropertyValue = "" Then
		PropertyValue = "Unknown"
	End If
	Return PropertyValue
End function
Sub ProcessItem(Item as TWmsScriptMediaItem)
	Dim SongName As String = GetProperty(Item, mpiTitle)
	Dim CollectionPath as String = "Song Index\" & Copy(SongName, 1, 1)
	WmsDatabaseAddLink(mfAudioPlaylistsItemID, CollectionPath, Item)
End Sub
Dim MediaItemList as TWmsScriptMediaItemList = WmsCurrentMediaListItems
Dim ItemIndex As Integer
try
	For ItemIndex = 0 To MediaItemList.Count - 1
		ProcessItem(MediaItemList[ItemIndex])
	Next
finally
	MediaItemList.Free
End Try
WmsDatabaseAutoSave
ProcessMediaResult = True
Posted: Fri Jan 01, 2010 1:41 pm
Perfectly, successes, good luck in New year :)
Posted: Wed Jan 06, 2010 10:40 am
by LouisXIV
Tried these scripts ....
Artist Index created a playlist with index, but I got several errors (see attachment) so I think I have to check my MP3 tags, do a rescan of the Media files and try again
Song Index does nothing here .... no new playlist created
Since I am no programmer I just executed what I copied here, no idea where to look for errors 8-)
Posted: Wed Jan 06, 2010 10:48 am
by LouisXIV
Oops ... too quick :oops:
Song Index DID do something, I now have a new playlist, but ..... not what I thought it would do. It created a songlist based on the filename I think, see for yourself in the attachment.
How can I correct this script?
Posted: Wed Jan 06, 2010 11:10 am
LouisXIV wrote:Oops ... too quick :oops:
There is a problem reading UNICODE-tags when scanning media resources, will be fixed in next version.
In what direction do you want to change the scripts?
Posted: Wed Jan 06, 2010 11:20 am
by LouisXIV
The UNICODE problem will be the problem with the "Artist index" script I guess, so there is indeed nothing for me to do than check my tags and wait for the next release.
The "Song index" script however seems to index my songs based on the filename (Eagles - Desperado - 01 - Doolin-Dalton.mp3 -> shows up under the E) instead of the trackname, in this case Doolin-Dalton should show up under the D
Posted: Wed Jan 06, 2010 2:38 pm
LouisXIV wrote:The UNICODE problem will be the problem with the "Artist index" script I guess, so there is indeed nothing for me to do than check my tags and wait for the next release.
Try changing ProcessItem
   Dim DelimPos = EndPos(SongName, " - ")
   If DelimPos > 0 Then
     SongName = Copy(SongName, DelimPos + 3, 2000)
   End If
End Sub
