facetele.com
Posted: Thu Sep 22, 2011 7:05 pm
by andrewappleseed
it could be possible to add to WMS this site:
http://www.facetele.com/tv-espana/
thanks!
Re: facetele.com
Posted: Thu Sep 22, 2011 7:36 pm
Re: facetele.com
Posted: Tue Sep 27, 2011 1:47 pm
by andrewappleseed
Thanks Eugene, it really works.
Some chanels seem to be not active.
How can i add a new channel using only the rmtp link?
Re: facetele.com
Posted: Sat Oct 01, 2011 5:09 am
Select the folder "Internet-television" - List [Movies] - right click - "Add link" - Path: rtmp-link - Ok - select a link - right click - "Transcoding profile" - "Movies - RTMPDUMP - FFMPEG"
You can use RtmpDump command line (rtmpdump.exe ...) without -o parameter as path of media-resource
