Access violation at address .... wms.dat
Posted: Thu Apr 21, 2011 9:38 am
by ajuga
Allmost every day I find the following error dialog on the screen when I logon to my media server (running mediaportal and wms):
File:C:\Documents and Settings\All Users.WINDOWS\Application Data\Wild Media Server\wms.dat
Fout laden:Access violation at address 00405A04 in module 'wms.exe'. Read of address FFFFFFFA.
Load Back-up?
No entry to be found in the log book, so no clue as to what is the reason and at what time it occured.
Version 1.08.3 (and all versions before that)
Extra information (not sure if it's of any importance): The following script runs every 10 minutes because wms doesn't allways read the properties of all recordings. Yesterday I disabled the statement WmsDatabaseAutoSave in a desperate attempt to find the source of the problem. But this didn't make any difference.
  AllVideoFolder: TWmsScriptMediaItem;
  AllVideoFolder := WmsFindMediaFolder(mfVideoAllMoviesItemID);
  if (AllVideoFolder <> nil) then
    for i := 0 to AllVideoFolder.ChildCount - 1 do
      if VarToStr(AllVideoFolder.ChildItems[i].Properties[mpiTimeLength]) > '1' then try
      AllVideoFolder.ChildItems[i].Properties[mpiTimeLength]:='01:00:00.000';
      except end;
      if VarToStr(AllVideoFolder.ChildItems[i].Properties[mpiTimeLength]) = '' then try
        AllVideoFolder.ChildItems[i].RetrieveProperties;
      except end;
  WmsLogMessage(mtiInfo,"read properties");
  //WmsDatabaseAutoSave;
  ProcessMediaResult := True
Re: Access violation at address .... wms.dat
Posted: Thu Apr 21, 2011 10:11 am
ajuga wrote:Allmost every day I get the following error
Load Back-up?
No entry to be found in log book, so no clue as to what is the reason.
Version 1.08.3 (and all version before that)
Extra information: The following script runs every 10 minutes because wms sometimes doesn't allways read the properties of all recorded file. Yesterday I disabled the statement WmsDatabaseAutoSave but this didn't make any difference.
if VarToStr(AllVideoFolder.ChildItems.Properties[mpiTimeLength]) > '1' then try
AllVideoFolder.ChildItems.Properties[mpiTimeLength]:='01:00:00.000';
except end;
if VarToStr(AllVideoFolder.ChildItems.Properties[mpiTimeLength]) = '' then try
AllVideoFolder.ChildItems.RetrieveProperties;
except end;
Try disable the script, properties will be read during preparation of list of media resources.
Posted: Thu Apr 21, 2011 1:06 pm
by ajuga
No they are NOT read allways. That's exactly the reason I implemented this script. This was your own suggestion. See your reply on topic
http://www.wildmediaserver.com/forum/vi ... 1982#p1982 (Fri Apr 30, 2010 3:58 pm)
To be short: The script is needed as long as the wms-doesnt-always-read-properties bug isn't fixed. By the way: Regardless of the fact that you can't reproduce the behaviour that wms doesn't always read the properties you should certainly be able to detect it and log it. The second reason I need this script is because of some files the length is wrong (see http://www.wildmediaserver.com/forum/vi ... 5394#p5394). I don't blame wms for this (allthough mediainfo has no problems with these files) but I DO have to take care of it, so I just force a length of 1 hour).
I have to accept the fact that wms is closed source, otherwise I could fix these problems myself. I have no problems with workarounds. But I just hate non-robustness. Whatever the cause is: Such an access violation should never occur and should be dealt by the developer and not by the user.
Posted: Thu Apr 21, 2011 2:09 pm
ajuga wrote:Try disable the script, properties will be read during preparation of list of media resources.
The program have processing for http://www.wildmediaserver.com/forum/vi ... 1982#p1982.
FFMPeg is open-source, so
You will help yourself and FFMPEG-developers :)
Posted: Thu Apr 21, 2011 2:36 pm
by ajuga
Forget the issue with wrong length. We are getting further away from the real issue. Which is: access violation reading wms.dat in wms.exe. This is a robustness problem which you have to solve in wms (exception handlers).
Posted: Thu Apr 21, 2011 3:37 pm
ajuga wrote:Forget the issue with wrong length. We are getting further away from the real issue. Which is: access violation reading wms.dat in wms.exe. This is a robustness problem which you have to solve in wms (exception handlers).
Can you provide wms.dat ? (eg to support@wildmediaserver.com)
Posted: Thu Apr 21, 2011 3:59 pm
by ajuga
You mean NOW or the next time the error occurs?
Posted: Thu Apr 21, 2011 4:22 pm
ajuga wrote:You mean NOW or the next time the error occurs?
At your convenience
Posted: Thu Jun 02, 2011 7:08 am
by ajuga
version 1.09.1 resolved the access violation
