YAMMM mymovies.xml import
Posted: Sat Feb 13, 2010 1:10 pm
by andyselects
Not sure whether this is any use for anybody.
I use YAMMM to automatically update my movie collection with data from IMDB. This creates a mymovies.xml file containing information about the actors/directors, ratings, genres etc. It also creates a folder.jpg and some other cover.jpgs too.
I've written a little script that will look in the folder of the movie for this mymovies.xml file and automatically populate this information within WildMediaServer. It'll also set the thumbnail image to the Folder.jpg.
Please feel free to use/modify the code in anyway.
I've not written any PascalScript before so go easy on me but I'd welcome any comments too.
NOTE: This will overwrite all the information you may have entered manually.
function GetThumbnail( XMLRoot : TXMLItem ) : string;
   var XMLCovers : TXMLItem  ;
   XMLCovers := XMLRoot.Find("Covers");
   Result := "";
   if XMLCovers <> nil then
      Result := XMLCovers.Find("Front").Value;
procedure GetPeople( XMLRoot : TXMLItem;
                     var actors : string;
                     var directors : string;
                     var producers : string;  );
   var XMLPeopleRoot : TXMLItem;
   var XMLPerson : TXMLItem;
   var Name: string;
   var i : Integer;
   actors := "";
   directors := "";
   producers := "";
   XMLPeopleRoot := XMLRoot.Find("Persons");
   if XMLPeopleRoot <> nil then begin
      for i := 0 To XMLPeopleRoot.Count - 1 do begin
         XMLPerson := XMLPeopleRoot[i];
         Name := XMLPerson.Find("Name").Value;
         if XMLPerson.Find("Type").Value = "Actor" then begin
            if Length(actors) = 0 then
               actors := Name
            else
               actors := actors + "," + Name
         else if XMLPerson.Find("Type").Value = "Director" then begin
            if Length(directors) = 0 then
               directors := Name
            else
               directors := directors + "," + Name
         else if XMLPerson.Find("Type").Value = "Producer" then begin
            if Length(producers) = 0 then
               producers := Name
            else
               producers := producers + "," + Name
function GetGenres( XMLRoot : TXMLItem ) : string;
   var XMLGenreRoot : TXMLItem;
   var genres : string;
   var i : Integer;
   XMLGenreRoot := XMLRoot.Find("Genres");
   genres := "";
   if XMLGenreRoot <> nil then begin
      for i := 0 To XMLGenreRoot.Count - 1 do begin
         if Length(genres) = 0 then
            genres := XMLGenreRoot[i].Value
         else
            genres := genres + "," + XMLGenreRoot[i].Value
   Result := genres;
function GetItemAsString(XMLRoot : TXMLItem; requiredData : string) : string ;
   var XMLItemData : TXMLItem;
   XMLItemData := XMLRoot.Find(requiredData);
   if XMLItemData <> nil then
      Result := XMLItemData.Value
   else
      Result := ""
procedure ImportMetaData(XMLRoot : TXMLItem; TheMediaItem : TWmsScriptMediaItem);
   var title, description, year, runningTime, rating: string;
   var actors, directors, producers : string;
   var XMLTitle: TXMLItem;
      title :=  GetItemAsString(XMLRoot, "LocalTitle");
      description := GetItemAsString(XMLRoot, "Description");
      rating := GetItemAsString(XMLRoot, "IMDBrating");
      year := GetItemAsString(XMLRoot, "ProductionYear");
      runningTime := GetItemAsString(XMLRoot, "RunningTime");
      TheMediaItem.Properties[mpiTitle] := title;
      TheMediaItem.Properties[mpiYear] := year;
      TheMediaItem.Properties[mpiComment] := description;
      TheMediaItem.Properties[mpiRating] := rating;
      TheMediaItem.Properties[mpiGenre] := GetGenres(XMLRoot);
      TheMediaItem.Properties[mpiThumbnail] := GetThumbnail(XMLRoot);
      GetPeople(XMLRoot, actors, directors, producers);
      TheMediaItem.Properties[mpiActor] := actors;
      TheMediaItem.Properties[mpiDirector] := directors;
      TheMediaItem.Properties[mpiProducer] := producers;
function GetMetaDataForItem(TheMediaItem : TWmsScriptMediaItem) : boolean;
var loadDir, movieXmlFileName, fullPath: string;
var XMLDocument: TXMLDocument;
   Result := false;
   movieXmlFileName := "mymovies.xml";
   loadDir := IncludeTrailingBackslash(ExtractFilePath(TheMediaItem.Properties[mpiFilePath]));
   fullPath := loadDir + movieXmlFileName;
   if FileExists(fullPath) then begin
      XMLDocument := TXMLDocument.Create;
      try
         XMLDocument.LoadFromFile(fullPath);
         if XMLDocument.Root.Name = "Title" then begin
            ImportMetaData(XMLDocument.Root, TheMediaItem);
            Result := true;
      finally
         XMLDocument.Free
  i, iSuccessCount: Integer;
  MediaItemList: TWmsScriptMediaItemList;
  MediaItemList := WmsCurrentMediaListItems;
  try
    iSuccessCount := 0;
    if MediaItemList.Count > 0 then begin
      WmsShowProgress('Load metadata...');
      try
        for i := 0 to MediaItemList.Count - 1 do begin
          if WmsCancelPressed then
            Break
          else begin
            if GetMetaDataForItem(MediaItemList[i]) then
               Inc(iSuccessCount);
            WmsSetProgress(Round(((i + 1) / MediaItemList.Count) * 100))
      finally
        WmsHideProgress
      MessageDlg('Load aborted by the user.', mtError, mbOK, 0)
    else if iSuccessCount > 0 then
      MessageDlg('Load metadata was successful.', mtInformation, mbOK, 0)
    else
      MessageDlg('No information available for load.', mtError, mbOK, 0)
  finally
    MediaItemList.Free
  WmsDatabaseAutoSave;
  ProcessMediaResult := True
Re: YAMMM mymovies.xml import
Posted: Sat Feb 13, 2010 5:43 pm
Great, I think it is in any case it will be useful to other users.
Posted: Wed Feb 17, 2010 4:50 pm
by mikinho
Hi, I'm the author of Yammm. If there is any interest in having Yammm create the native metadata for Wild Media Server directly please let me know and I'd be happy to add it.
Posted: Wed Feb 17, 2010 5:15 pm
mikinho wrote:Hi, I'm the author of Yammm. If there is any interest in having Yammm create the native metadata for Wild Media Server directly please let me know and I'd be happy to add it.
Thanks for the offer, but the metadata WMS is very native (number-based). I do not think it will be convenient for you. Rather, the WMS will be added to support any format that supports Yammm.
Posted: Mon Mar 08, 2010 9:19 pm
by snifferr
I've just downloaded WMS as i love the idea of building a DLNA server using mymovies.xml metadata.
Please could you explain how i run the above code to populate the movie details and folder.jpg to WMS?
Many thanks in advance.
Snifferr
Posted: Wed Mar 10, 2010 7:34 am
Snifferr
Example, http://www.wildmediaserver.com/forum/vi ... p=452#p452
Posted: Wed Aug 11, 2010 7:59 pm
by manichon
Hello, noob here, just one question, do I have to select a movie folder and then click on the button for the script or is there a way for the script to run automatically on every movie folder?
Posted: Thu Aug 12, 2010 8:00 am
manichon wrote:do I have to select a movie folder and then click on the button for the script or is there a way for the script to run automatically on every movie folder?
Modified version http://www.wildmediaserver.com/forum/vi ... 3357#p3357
Posted: Fri Aug 13, 2010 9:05 pm
by manichon
Thanks a lot Eugene!
