DVB with WMS and VLC
Posted: Wed Mar 23, 2011 7:31 am
by moell9
I have configured my digital TV card in WMS. I also found several broadcast stations like the german ARD and ZDF.
I did a Test-Transcoding and everything is fine - I found the data in the temporary folder and I was also able to use VLC with it.
But I'm not able to play my stations directly in WMS. With a doubleclick I get a window "open with" and I choose VLC and confirm with OK but nothing happens.
In other sections like normal video everything is running as aspected with VLC.
My system: Windows 7 - WMS 1.09RC2 - VLC 1.1.7
Re: DVB with WMS and VLC
Posted: Wed Mar 23, 2011 8:31 am
moell9 wrote:I have configured my digital TV card in WMS. I also found several broadcast stations like the german ARD and ZDF.
Use web-navigation: http://server_ip_address_:port
Settings - Server - choose a device - Edit - Settings - turn on Web
Posted: Wed Mar 23, 2011 7:30 pm
by moell9
Yes, that works - thank you !!!
Posted: Wed Mar 23, 2011 8:19 pm
by moell9
Now I want to stream my video files and the DVB signal to my television set (SONY Bravia).
With mpg files I have no problems.
But I have also files in ts format and the DVB signal is also ts.
Is it possible to run this too ?
Posted: Thu Mar 24, 2011 2:26 pm
moell9 wrote:Now I want to stream my video files and the DVB signal to my television set (SONY Bravia).
What kind of problem ?
Posted: Thu Mar 24, 2011 3:19 pm
by moell9
These
ts files are not running on my TV set.
Posted: Fri Mar 25, 2011 1:35 am
moell9 wrote:But I have also files in ts format and the DVB signal is also ts.
These
Try the transcoding profile "Digital television (DVB) - DVPiper"
Posted: Fri Mar 25, 2011 2:33 am
by moell9
That's the profile I took . . .
Posted: Sun Mar 27, 2011 3:16 pm
by moell9
It's working now.
I installed the WMS from scratch, and everything is fine !!!
But, I think the SONY profile doesn't work for me. I have a SONY Bravia 32EX715. I just took the standard profile.
Another question: How can I sort my TV channels in the DVB section ? My sorting begins for example with:
Das Erste
ZDF
NDR
SWR
RTL
SAT1
. . . and so on.
It should not be alphabetically and not random.
Posted: Tue Mar 29, 2011 6:41 pm
moell9 wrote:It's working now.
Das Erste
ZDF
NDR
SWR
RTL
SAT1
. . . and so on.
TV Remote Control - Options
