Page 2 of 5
Re: Links to the problematic media resources
Posted: Tue Dec 22, 2009 1:04 pm
DEvil HUnter wrote:the key has the value 2..
tryed the value 0 - no effect...
(have win 7 pro)
the path i have problem with is:
i think the problem is the ü as before..
D:\Musik\christina stürmer\videos\Christina Stürmer - Mehr Waffen Video.avi
Change the value has no effect on old catalogs, only the new and requires rebooting.
In any case, i will try to invent something to solve the problem.
Posted: Sat Jan 09, 2010 1:26 pm
by Rocko
Hi, I have the same problem with the German umlauts (äöü). Is there already a solution?
Thank you for the WMS, otherwise it works perfectly with my SONY Bravia.
Sorry my english is not the best.
Posted: Sat Jan 09, 2010 4:07 pm
Rocko wrote:Hi, I have the same problem with the German umlauts (äöü). Is there already a solution?
If your native language contains German umlauts (äöü), try switching to the Regional Settings (Control Panel) the native language for non-Unicode programs. The program is a fix for this problem, but it seems it does not always work.
Posted: Tue Jan 26, 2010 1:09 pm
by ha100
"RTVTelevision 80s 90s Top Hits" from Shoutcast tv
http://www.shoutcast.com/sbin/tunein-tv ... ?id=175658 does not play on W5500. Plays fine on PS3.
Tried transcoding profiles internet tv, internet tv demux, internet tv input stream, Movies (Primary). Wil try some more but don't think it will work. This channel has a stange resolution. Very small image.
Posted: Fri Jan 29, 2010 9:21 pm
by DLOQUET
I think I have the same problem with accented characters in French.
below the console when I test with a file containing accented characters:
C:\WMS>"C:\WMS\wmsmpeg.exe" -i "C:\Users\user\Music\Sonerien Treujenn Gaol\Son
neurs de clarinette en BRETAGNE\01 Daßs faßch an Danou½t.wma" -f s16be -ac 2 -ar
44100 "C:\Users\Didier\AppData\Local\Wild Media Server\WMS\Temp\Test_ea4ba6e4d
47fb5a61f5fd6b5d141b239.s16be" -v -1
FFmpeg version SVN-r20212, Copyright (c) 2000-2009 Fabrice Bellard, et al.
built on Dec 19 2009 00:45:55 with gcc 4.2.4 [Sherpya]
libavutil 50. 3. 0 / 50. 3. 0
libavcodec 52.37. 0 / 52.37. 0
libavformat 52.39. 0 / 52.39. 0
libswscale 0. 7. 1 / 0. 7. 1
C:\Users\user\Music\Sonerien Treujenn Gaol\Sonneurs de clarinette en BRETAGNE\
01 Da?s fa?ch an Danou?t.wma: no such file or directory
C:\WMS>pause
Appuyez sur une touche pour continuer...
And below the console when I test with a file without accented characters:
C:\WMS>"C:\WMS\wmsmpeg.exe" -i "C:\Users\user\Music\Louise Attaque\Louise Atta
que\01 Amours.wma" -f s16be -ac 2 -ar 44100 "C:\Users\Didier\AppData\Local\Wild
Media Server\WMS\Temp\Test_a43145bdd4ffb3f69854f2fbf9353674.s16be" -v -1
Input #0, asf, from 'C:\Users\user\Music\Louise Attaque\Louise Attaque\01 Amou
rs.wma':
Duration: 00:01:57.63, start: 1.579000, bitrate: 130 kb/s
Stream #0.0(eng): Audio: wmav2, 44100 Hz, 2 channels, s16, 128 kb/s
Metadata
Lyrics :
MediaPrimaryClassID: {D1607DBC-E323-4BE2-86A1-48A42A28441E}
WMFSDKVersion : 11.0.6001.7001
WMFSDKNeeded : 0.0.0.0000
IsVBR : 0
Year : 1998
EncodingTime : 2100859008
UniqueFileIdentifier: AMGa_id=R 375646;AMGp_id=P 320476;AMGt_id=T 51400
55
Composer : Gaëtan Roussel
Publisher : Atmospheriques
Genre : World
AlbumTitle : Louise Attaque
AlbumArtist : Louise Attaque
MCDI : E+96+230C+5903+87DC+A98F+D5FC+1000E+11F35+142A0+17C8E+1AED
2+1E645+21101+270C6+2AD70
Provider : AMG
ProviderStyle : Rock
PeakValue : 32545
AverageLevel : 8059
TrackNumber : 1
title : Amours
author : Louise Attaque
copyright :
comment :
Output #0, s16be, to 'C:\Users\Didier\AppData\Local\Wild Media Server\WMS\Temp\T
est_a43145bdd4ffb3f69854f2fbf9353674.s16be':
Stream #0.0(eng): Audio: pcm_s16be, 44100 Hz, 2 channels, s16, 1411 kb/s
Stream mapping:
Stream #0.0 -> #0.0
size= 20272kB time=117.68 bitrate=1411.2kbits/s
C:\WMS>pause
How to solve this ?
Posted: Sat Jan 30, 2010 5:28 am
How to solve this ?
Try switching to the Regional Settings (Control Panel) the language for non-Unicode programs to French.
Posted: Sat Jan 30, 2010 11:13 am
by DLOQUET
unfortunatly, settings were already in french for non unicode programs
Posted: Sat Jan 30, 2010 11:31 am
DLOQUET wrote:unfortunatly, settings were already in french for non unicode programs
What operating system?
Posted: Sat Jan 30, 2010 11:35 am
by DLOQUET
Vista edition familiale premium
SP2
Posted: Sat Jan 30, 2010 12:07 pm
DLOQUET wrote:Vista edition familiale premium
SP2
Try "Run As Administrator", the program can create symbolic links to the problematic media-resources,
the program can create hard links to the problematic media-resources (not need to run "Run As Administrator", but require a change wms.cfg in notepad <HardLinksDirectory>\WmsLinks</HardLinksDirectory>)
