Page 2 of 2
Re: ESPN3
Posted: Sat Jul 09, 2011 5:21 am
Re: ESPN3
Posted: Sat Jul 09, 2011 10:28 am
by 2ez24get
Upgraded to 1.10rc7 and still have Loading... on TV when selecting any ESPN3 stream. Any info you need to help fix this issue?
Re: ESPN3
Posted: Sat Jul 09, 2011 1:22 pm
Test transcoding works ?
Re: ESPN3
Posted: Sat Jul 09, 2011 2:10 pm
by 2ez24get
Running the Transcoding test and the process hangs with the text below. Ran test against ESPN and they work see below.
ESPN3 Transcoding Test:
"C:\Program Files\Wild Media Server\wmsmpeg.exe" -probesize 7000000 -analyzedura
tion 5000000 -i "\\.\pipe\386C9D2FF641459EAF516A4F95FD1005" -f dvd -vcodec mpeg2
video -b 8000000 -aspect 16:9 -copyts -pix_fmt yuv420p -acodec ac3 -ab 448000 -
ar 48000 "C:\Users\Rn\AppData\Local\Wild Media Server\WMS\Temp\Test_d6838b
a790f32079bb6a2a1dad5e9eb3.mpg" -v -1 -loglevel quiet
built on Jun 9 2011 21:18:55 with gcc 4.5.0
ESPN Transcoding Test:
tion 5000000 -i "\\.\pipe\35695A7896A842F0921A893228D2905C" -f dvd -vcodec mpeg2
ar 48000 "C:\Users\Rn\AppData\Local\Wild Media Server\WMS\Temp\Test_731893
a335bcd408e37dc73ea3fb8fa6.mpg" -v -1 -loglevel quiet
[flv @ 01b05d60] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 1000.00 (1000
/1) -> 24.00 (24/1)
Input #0, flv, from '\\.\pipe\35695A7896A842F0921A893228D2905C':
Metadata:
duration : 308
width : 576
height : 324
framerate : 24
canSeekToEnd : true
videocodecid : 4
videodatarate : 800
audiocodecid : 2
audiosamplerate : 44100
audiosamplesize : 16
Duration: 00:05:07.70, start: 0.000000, bitrate: 915 kb/s
Stream #0.0: Video: vp6f, yuv420p, 576x324, 819 kb/s, 24 tbr, 1k tbn, 1k tbc
Stream #0.1: Audio: mp3, 44100 Hz, 1 channels, s16, 96 kb/s
Output #0, dvd, to 'C:\Users\Rn\AppData\Local\Wild Media Server\WMS\Temp\T
est_731893a335bcd408e37dc73ea3fb8fa6.mpg':
: Video: mpeg2video, yuv420p, 576x324 [PAR 1:1 DAR 16:9], q=2-31, 8000 kb/s, 90k
tbn, 24 tbc
: Audio: ac3, 48000 Hz, mono, s16, 448 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Press [q] to stop encoding
frame= 129 fps= 0 q=2.0 size= 846kB time=5.33 bitrate=1299.5kbits/s dup=2
frame= 256 fps=249 q=2.0 size= 2100kB time=10.62 bitrate=1619.1kbits/s dup=5
frame= 375 fps=243 q=2.0 size= 3548kB time=15.58 bitrate=1865.1kbits/s dup=7
frame= 474 fps=230 q=2.0 size= 5080kB time=19.71 bitrate=2111.6kbits/s dup=8
frame= 562 fps=218 q=2.0 size= 6616kB time=23.38 bitrate=2318.6kbits/s dup=1
frame= 657 fps=213 q=2.0 size= 8376kB time=27.33 bitrate=2510.3kbits/s dup=1
Re: ESPN3
Posted: Sat Jul 09, 2011 4:58 pm
Probably rtmpdump.exe (?:\Program Files\Wild Media Server\Transcoders) blocked by firewall
Re: ESPN3
Posted: Sat Jul 09, 2011 5:59 pm
by 2ez24get
Eugene I added the exception to the firewall and it works! You are a Genius! Got it working with 1 min to spare.
