Page 2 of 2
Re: Sont KDL-37W5810 and WMS
Posted: Sun May 30, 2010 10:39 am
dgat wrote:Eugene wrote:dgat wrote:
Problem now is the framing has no effect at all on any 16:9 programs (i.e. TV shows) - the frame is not in the transcoded files for these. I have set it to always scale but to no effect plus played with all sorts of sizes and profiles.
I guess I can live with this but it seems weird - there must be some logic behind it deciding not to frame these - I have even set my orig frame to be 4:3 to see if that forces it but to no avail.
For the server, no matter the content of media resources (i.e. TV shows), but its work may depend on it file type.
Thats weird then - the file types are all AVI regardless of the aspect ratio
If the padding value from all sides equal 0, WMS really does not add a frame border. This can not be changed for the Movies (primary), but you can change transcoding profile Movies (additional) - Settings - Transcoder - Profiles - Movies (additional) - Edit
if (iPadLeft > 0) or (iPadRight > 0) or (iPadTop > 0) or (iPadBottom > 0) then begin
sParams := sParams + Format(' -padleft %d -padright %d -padtop %d -padbottom %d -padcolor %s',
[iPadLeft, iPadRight, iPadTop, iPadBottom, WmsConvertColor(cfgTranscodingPadColor)]);
if cfgTranscodingFrameExists then
sParams := sParams + cfgTranscodingFrameParams;
Inc(iFrameWidth, iPadLeft + iPadRight);
Inc(iFrameHeight, iPadTop + iPadBottom);
replace on
Posted: Sun May 30, 2010 4:18 pm
by dgat
Thanks Eugene
I have made that change in Movies (additional) and selected that Transcoder Profile and tested again - exactly the same I am afraid - my 16:9 files have no padding but others do.
Posted: Sun May 30, 2010 6:02 pm
1. Select problematic file in list.
2. Settings-Transcoder-Profiles-Movies (additional) - Edit - click green button Check.
3. What transcoding parameters ? (on right click mouse "Copy to clipboard")
Posted: Sun May 30, 2010 6:27 pm
by dgat
Result: -i "<INPUT FILE>" -f dvd -vcodec mpeg2video -b 8000000 -aspect 16:9 -copyts -pix_fmt yuv420p -acodec ac3 -ab 448000 -ar 48000
By stepping through the script I can see where it is failing - its at if (iWidth > 0) and (iHeight > 0) then begin - at that point the if is false for some reason so it misses that whole chunk of code out! (ran it through with one that works and that section is triggered by the if statement).
Posted: Sun May 30, 2010 6:34 pm
On right click mouse "Load file properties" in list of movies
Posted: Sun May 30, 2010 6:47 pm
by dgat
On right click mouse "Load file properties" in list of movies[/quote]
No real diff between one that works and one that doesnt (apart from the obv)
Working
Video MPEG4 (XVID) 0 23.976 720x304 45:19
Not Working
Video MPEG4 (XVID) 0 23.976 624x352 39:22
Posted: Mon May 31, 2010 6:23 am
dgat wrote:On right click mouse "Load file properties" in list of movies
Working
Not Working
On step
You can see the value of variables iWidth, iHeight. Button with calculator image.
Posted: Mon May 31, 2010 10:02 am
by dgat
Eugene wrote:dgat wrote:On right click mouse "Load file properties" in list of movies
Working
Not Working
On step
This is crazy - I just used the calculator and it correctly shows the correct Width and Height and guess what! It all starts working AOK!!! I have made no changes at all since it wasn't working yesterday - maybe exposing the properties has forced them to work? I am gonna try again getting on I havent forced the properties load and see what happens.
Posted: Mon May 31, 2010 10:07 am
by dgat
dgat wrote:Eugene wrote:dgat wrote:On right click mouse "Load file properties" in list of movies
Working
Not Working
On step
Bingo yes - if you dont load file properties prior to playing it doesnt work - if you do then it does!
