Released version "Wild Media Server (DLNA) v1.80.1 (64-bit)
Locked
Update to 1.80.1
Wild Media Server (UPnP, DLNA, HTTP) v.1.80
1. Individual settings of the client device - Transcoder - "Files, subtitles" - "Transcoding file parameters" - Music:
  • added setting a fixed tags size in the transcoded audio files (default 0 - metadata is not included in the transcoded file).
2. Updated transcoder ffmpeg-1.dll (adds support for parameter tags_size).
3. The registration of file types:
  • changed separator for MIME-types (from comma to |).
4. Updated the transcoding profiles of music files - changes for support tags_size (if the transcoding profiles changed, it is recommended to restore the profiles from the distribution kit).
5. Added hotkey (Alt+5) for call script of dynamic folder.
6. Added support for loading podcasts configurations from zip-files ("Drag and drop" and "Load from file").
7. Added support for saving podcasts configurations to zip-files ("Save to file").
8. The form of control DMR (Digital Media Renderer) device:
  • added button "Play to" - play the current media resource on selected device from the current position.
9. Updated module MediaInfo.dll.
Re: Released version "Wild Media Server (DLNA) v1.80.1 (64-b
Update to 1.80.1
1. Added hotkey (Alt+5) for call script of dynamic folder.
2. Added support for loading podcasts configurations from zip-files ("Drag and drop" and "Load from file").
3. Added support for saving podcasts configurations to zip-files ("Save to file").
4. The form of control DMR (Digital Media Renderer) device:
5. Updated module MediaInfo.dll.
Locked
