I need change my PS3, what I have to do?
chinowt
Post by chinowt »
If I need change my PS3, I have to buy another license?
Re: I need change my PS3, what I have to do?
chinowt wrote: If I need change my PS3, I have to buy another license?
If the device is replaced by the manufacturer's warranty, you can get a new activation code for free. If you buy a new device and it has a different Device Code, then you need to buy a new license.
chinowt
Post by chinowt »
The only way to avoid having to buy a new license is changed by warranty, but I understand that if it breaks out of warranty, I have to buy another license, right?
chinowt wrote: The only way to avoid having to buy a new license is changed by warranty, but I understand that if it breaks out of warranty, I have to buy another license, right?
Yes, it's right.
4. If you do not have enough trial period to test the program or if you have already bought a license and want to test it out with another device, you can apply by mail info@wildmediaserver.com for a free activation code on 15 days (required the Device Code).
chinowt
Post by chinowt »
Ok Eugene, thank you for all.
See you.
