Device configuration "LG BD Player (DLNA, 16:9, 720x406)"
Update on version 1.04.1 (1.04-1.04.1)
- added device configuration "LG BD Player (DLNA, 16:9, 720x406)";
k10ck3r
Re: Device configuration "LG BD Player (DLNA, 16:9, 720x406)"
Post by k10ck3r »
Looks good. I don't know if it was the configuration change to a 2MB buffer size, or a recent firmware update to my BD-570, but the 30 second delay is gone!
On a side note, the list of file types I generated for my configuration file is slightly different. Not sure which is completely correct, as I just went from the documentation for the player. Either way - good job.
k10ck3r
Oh, also - for the 570 a thumbnail size of 300x300 looks a lot better than the default 160x160.
k10ck3r wrote:Looks good. I don't know if it was the configuration change to a 2MB buffer size, or a recent firmware update to my BD-570, but the 30 second delay is gone!
Player waiting for closing the connection, when working with subscriptions
k10ck3r wrote: On a side note, the list of file types I generated for my configuration file is slightly different. Not sure which is completely correct, as I just went from the documentation for the player.
The player supports files that are not in the documentation, but unfortunately, does not support VC1 (on files that I tried)
k10ck3r wrote: Oh, also - for the 570 a thumbnail size of 300x300 looks a lot better than the default 160x160.
Well, I'll change.
kerio wrote:is there going to be LG BD Player (DLNA, 16:9, 1920x1080)?
Settings - Transcoder - "Codecs, frame" - Frame size
without transcoding?
File is transferred without change
