MKV problem
khalighi
MKV problem
Post by khalighi »
First of all i want to thank you about this software it's really great but my only problem is with .MKV files it works but when i try to fast forward or scene search everything goes wrong.
I hope someone can help me.
Re: MKV problem
khalighi wrote:First of all i want to thank you about this software it's really great but my only problem is with .MKV files it works but when i try to fast forward or scene search everything goes wrong.
PS3 does not support mkv, use the positioning by time
khalighi
Re: MKV problem
Post by khalighi »
I tried positioning by time and it worked but i can't open subtitles.
Thank you for your support
Re: MKV problem
khalighi wrote:I tried positioning by time and it worked but i can't open subtitles.
You have chosen to use subtitle track ?
In the tracks of film (main form of program), or in the folder Settings (navigation via folder Transcoding)
khalighi
Re: MKV problem
Post by khalighi »
Now the video is working with subtitle, but i still have a problem with sound (audio delay) when I try to fast forward or scene search, it will be great if you can Help me.
Khalighi
Re: MKV problem
khalighi wrote:Now the video is working with subtitle, but i still have a problem with sound (audio delay) when I try to fast forward or scene search, it will be great if you can Help me.
Use the positioning by time, for transcoded content is the best solution.
khalighi
Re: MKV problem
Post by khalighi »
Can you please check those pictures and tell me if there is something wrong with my settings.
http://yfrog.com/9fcaptureylj
http://yfrog.com/emcapture2aej
Re: MKV problem
khalighi wrote:Can you please check those pictures and tell me if there is something wrong with my settings.
PS3 has a choice time position where you want to go.
khalighi
Re: MKV problem
Post by khalighi »
Problem solved with the new WMS version 1.04 and now MKV files are working with subtitles without any problems. I really care to know what fixes this issue.
