Dear Eugene
What a job thanks thousand times.
I tryes a few scripts, it was fine but I am really blocked with watchtvfree
I did get my userid correct 5by the way the source codes mention flashvars.username not flashvars.userid (mistake on my side ?)
Seems I have no thumbnail and when I check the transcoding I get "no such file or directory"
I has been a few weekd now I start to be desparate. I checked the forum but the outcome is still not there
Sorry to boither I might be to silly to use the scripts
Thanks again
jeando
watchtvfree
Re: watchtvfree
I checked - no problems with flashvars.userid and videos. What a link ?jeando wrote: I tryes a few scripts, it was fine but I am really blocked with watchtvfree
Re: watchtvfree
Thanks Eugene
all links receive the same answer.
exemples Bones season 1 ep6 desperate housewives season1 ep6
Re: watchtvfree
Internet Explorer - http://www.megavideo.com - choose any video - right click - View source - Ctrl+F - flashvars.userid
Re: watchtvfree
Fantasfic
works perfect
thanks a lot
great soft
works perfect
thanks a lot
great soft
Re: watchtvfree
Another silly question
on this watchtcfreeshow I cannot advance from the remote
as I can do this while watching from the PC on IE8
I can advance with other podcats.
Is it possible to display in HD or is the source SD
Thanks again
jeando
Thanks again
jeando
