Re: Stuttering PC transcode after a few minutes.
Posted: Fri Feb 11, 2011 9:19 pm
If you really need transcoding and computer performance is not enough, then you can use pre-transcoding - http://www.wildmediaserver.com/forum/vi ... &f=3#p3301drem wrote:I get stuttering after a few minutes when PC transcoding. Tried switching to TsMuxer but it did not difference. Also tried increasing the transfer data buffer size from 512kb to 8192kb. Only difference was the transcoding takes 10 seconds longer to start playing the file but the stuttering begins at pretty much the same place, maybe 5-6 minutes into the movie.
What can I do?
(My player has a 1Gb built in flash memory)
