PODCAST Problems
morefield
Re: PODCAST Problems
Post by morefield »
It is strange. Playback works on the website, but not on my television. I tried by transcoding with "Internet Television" but then I get the message that the server is not available.. I tried the MTV podcast and it works flawless (without transcoding). Also with transcoding I receive the message that the server is not available.
morefield
Post by morefield »
The 'internet television' transcoding now does not lead to the message that Server is not available anymore. But the problem remains that "Uitzending gemist" stops after a couple of minutes...unfortunataly.
Test transcoding with "Internet-television" ?
morefield
Post by morefield »
No errors during testing. So it must be my tv or something?
You can try to play transcoded file on your computer and TV via USB.
Hilljoh
Post by Hilljoh »
Ciao Echine,
I have the same problems on my ps3, i've removed also mpinternetitem etc.etc. tried the newest version and older versions of vlc but nothing works, after 2 minutes the streaming stops. In pms the streaming huks more ore less at the same position but will continue playing. I prefer wms because the dutch rlt plugin is much better working than in pms, when uitzendinggemist is working I only can use WMS! Tonight during test decoding I find out when the time > 50 the making of new framelines begin. When time > 100 the decoding stops. report of decoder information: FFmpeg version SVN-r25702, Copyright (c) 2000-2010 the FFmpeg developers
[asf @ 0022b130] max_analyze_duration reached
Seems stream 1 codec frame rate differs from container frame rate: 1000.00 (1000/1) -> 25.00 (25/1)
Input #0, asf, from 'mmst://wm-ondemand01a.omroep.nl/public/ug-od/wm/3/media/wm3c1/ceres/1/kro/rest/2011/KRO_1421959/std.20110130.wmv?wmt=4d4896ad&wmhash=44cf66dc':
Metadata:
title :
artist :
copyright :
comment :
WM/ToolName : FlipFactory
WM/ToolVersion : 4.2
Duration: 00:49:15.32, start: 5.000000, bitrate: N/A
Stream #0.0(eng): Audio: wmav2, 44100 Hz, 2 channels, s16, 128 kb/s
Stream #0.1(eng): Video: vc1, yuv420p, 640x360, 890 kb/s, 25 tbr, 1k tbn, 1k tbc
[buffer @ 01cca3c0] w:640 h:360 pixfmt:yuv420p
[ac3 @ 01c23a60] No channel layout specified. The encoder will guess the layout, but it might be incorrect.
[dvd @ 01c2c7a0] VBV buffer size not set, muxing may fail
Output #0, dvd, to 'C:\Users\bear\AppData\Local\Wild Media Server\WMS_\Temp\c8cfaab6cf139834e8d73e2cc0109cfc.mpg':
Metadata:
encoder : Lavf52.84.0
Stream #0.0(eng): Video: mpeg2video, yuv420p, 640x360 [PAR 1:1 DAR 16:9], q=2-31, 3000 kb/s, 90k tbn, 25 tbc
Stream #0.1(eng): Audio: ac3, 48000 Hz, stereo, s16, 448 kb/s
Stream mapping:
Stream #0.1 -> #0.0
Stream #0.0 -> #0.1
Press [q] to stop encoding
Server sent an error status code: 0x51731ae4
Corrupt stream (unexpected packet type 0xffffffea, expected 0x10001)
[asf @ 0022b130] ff asf skip 8017 (unknown stream)
[asf @ 0022b130] ignoring invalid packet_obj_size (1926 1892 3647 5161)
[asf @ 0022b130] freeing incomplete packet size 5161, new 4392
Regards,
Hill
Hilljoh wrote: I have the same problems on my ps3, i've removed also mpinternetitem etc.etc. tried the newest version and older versions of vlc but nothing works, after 2 minutes the streaming stops. In pms the streaming huks more ore less at the same position but will continue playing. I prefer wms because the dutch rlt plugin is much better working than in pms, when uitzendinggemist is working I only can use WMS! Tonight during test decoding I find out when the time > 50 the making of new framelines begin. When time > 100 the decoding stops. report of decoder information: FFmpeg version SVN-r25702, Copyright (c) 2000-2010 the FFmpeg developers
Metadata:
title :
artist :
copyright :
comment :
Metadata:
Stream mapping:
Stream #0.1 -> #0.0
Stream #0.0 -> #0.1
You have not used "Internet-television"
Hilljoh
Post by Hilljoh »
I've checked again and tried 3 different things
1) using the standard settings the testcoding is starting well but than I got below error about 30....55 seconds. The streaming will continue unit 90...110seconds and then stops.
error message:
2) I removed the mpinternet part.
Now the test decoding will not start at all.
3) Ive used a different profiles 'movies - direct show - wtv' and 'movies - primary_1980' and 'movies additional', no I have the same error problem as unter point 1). Profile 'movies - ts_muxer' will not give errors in the beginning and at 30-55 second, but the test is closing about 100-115 seconds.
When I start the stream in internet explorer there are no problems.
I'm using windows 7. I've tested above things with vlx 0.9.8
After installing vlc 1.1.7 everything is working fine, thanks!
regards Hill
milko
Post by milko »
I have the same problem. After two minutes it stops playing and skips to the next file in the podcast list.
Transcoding test with 'internet-televison' shows no problems.
It's not just with the Uitzendinggemist podcast. It's with all podcast i tried so far.
They all work fine for the first two minutes and then stop, loads the next file in the podcast and plays that one for 2 minutes.
Like Morefield I have a Sony Bravia tv (EX500)
Please below the log of test transcoding
"C:\Program Files\Wild Media Server\wmsmpeg.exe" -probesize 7000000 -analyzedura
tion 5000000 -i "mmst://wm-ondemand11b.omroep.nl/public/ug-od/wm/3/media/wm3c2/c
eres/1/avro/rest/2011/AVRO_1409270/std.20110303.wmv?wmt=4d716a72&wmhash=70caade"
-f dvd -vcodec mpeg2video -b 6000000 -aspect 16:9 -copyts -pix_fmt yuv420p -s
640x360 -threads 2 -acodec ac3 -ab 448000 -ar 48000 -ac 2 -map 0:1 -map 0:0 "C:\
Users\AppData\Local\Wild Media Server\WMS\Temp\Test_6d5070997c
c76d1bdcc85f573a2d6737.mpg" -v -1 -loglevel quiet
FFmpeg version SVN-r26402, Copyright (c) 2000-2011 the FFmpeg developers
built on Mar 2 2011 21:53:48 with gcc 4.5.0
[asf @ 003ea0d0] max_analyze_duration reached
/1) -> 25.00 (25/1)
Input #0, asf, from 'mmst://wm-ondemand11b.omroep.nl/public/ug-od/wm/3/media/wm3
c2/ceres/1/avro/rest/2011/AVRO_1409270/std.20110303.wmv?wmt=4d716a72&wmhash=70ca
ade':
Metadata:
title :
artist :
copyright :
comment :
Duration: 00:50:10.88, start: 5.000000, bitrate: N/A
Stream #0.1(eng): Video: vc1, yuv420p, 640x360, 889 kb/s, 25 tbr, 1k tbn, 1k
tbc
Output #0, dvd, to 'C:\Users\Milko Zuijdendorp\AppData\Local\Wild Media Server\W
MS\Temp\Test_6d5070997cc76d1bdcc85f573a2d6737.mpg':
(eng): Video: mpeg2video, yuv420p, 640x360 [PAR 1:1 DAR 16:9], q=2-31, 6000 kb/s
, 90k tbn, 25 tbc
(eng): Audio: ac3, 48000 Hz, stereo, flt, 448 kb/s
Stream mapping:
Stream #0.1 -> #0.0
Stream #0.0 -> #0.1
frame= 1321 fps= 27 q=2.0 size= 23374kB time=52.80 bitrate=3626.5kbits/s dup=4
frame= 1336 fps= 27 q=1.6 size= 23580kB time=53.40 bitrate=3617.4kbits/s dup=4
frame= 1352 fps= 27 q=2.0 size= 23768kB time=54.04 bitrate=3603.0kbits/s dup=4
frame= 1370 fps= 27 q=2.0 size= 23976kB time=54.76 bitrate=3586.8kbits/s dup=4
frame= 1386 fps= 27 q=2.0 size= 24192kB time=55.40 bitrate=3577.3kbits/s dup=4
frame= 1399 fps= 27 q=2.0 size= 24372kB time=55.92 bitrate=3570.4kbits/s dup=4
frame= 1419 fps= 27 q=2.0 size= 24580kB time=56.72 bitrate=3550.1kbits/s dup=4
frame= 1435 fps= 27 q=2.0 size= 24790kB time=57.36 bitrate=3540.4kbits/s dup=4
frame= 1451 fps= 27 q=2.0 size= 24970kB time=58.00 bitrate=3526.8kbits/s dup=4
frame= 1470 fps= 27 q=2.0 size= 25210kB time=58.76 bitrate=3514.6kbits/s dup=4
frame= 1485 fps= 27 q=2.0 size= 25378kB time=59.36 bitrate=3502.3kbits/s dup=4
frame= 1498 fps= 27 q=2.0 size= 25518kB time=59.88 bitrate=3491.0kbits/s dup=4
frame= 1517 fps= 27 q=2.0 size= 25760kB time=60.64 bitrate=3480.0kbits/s dup=4
frame= 1535 fps= 27 q=2.0 size= 25946kB time=61.36 bitrate=3464.0kbits/s dup=4
frame= 1550 fps= 27 q=2.0 size= 26114kB time=61.96 bitrate=3452.6kbits/s dup=4
frame= 1569 fps= 27 q=2.0 size= 26350kB time=62.72 bitrate=3441.6kbits/s dup=4
frame= 1584 fps= 27 q=2.0 size= 26526kB time=63.32 bitrate=3431.8kbits/s dup=4
frame= 1598 fps= 27 q=2.0 size= 26686kB time=63.88 bitrate=3422.2kbits/s dup=4
frame= 1616 fps= 27 q=2.0 size= 26912kB time=64.60 bitrate=3412.7kbits/s dup=4
frame= 1634 fps= 27 q=2.0 size= 27100kB time=65.32 bitrate=3398.7kbits/s dup=4
frame= 1647 fps= 27 q=2.0 size= 27316kB time=65.84 bitrate=3398.7kbits/s dup=4
frame= 1660 fps= 27 q=1.6 size= 27470kB time=66.36 bitrate=3391.1kbits/s dup=4
frame= 1674 fps= 27 q=2.0 size= 27702kB time=66.92 bitrate=3391.1kbits/s dup=4
drop=0
guido
Post by guido »
Hi, I'm experiencing the same problems. Installed the uitzendinggemist plugin and everything I try to watch stops after about roughly 2 minutes.
After I did set the transcoding profile for uitzendinggemist I updated all the feeds.
I also didn't have VLC installed yet so i got the latest version form the official VLC website and configured the VLC installation path in WMS correctly. (it was already ok when installing VLC in default folder)
At this moment I'm testing one of the uitzendinggemist streams "wie is de mol?" that previously stopped after 2 minutes. I'm at 12 minutes 10 seconds when I write this. So the suggestions given in this thread do seem to work for me. I'm using a PS3 to watch the show.
