I purchased a license!
Looking at the trans-coding chart, TsMuxer is supposed to process FLV and WMV if I understand it correctly but on my Sony-S570 TsMuxer does not play WMV or FLV. I have to use various other profiles that clearly don't do as good a job as TsMuxer does with the rest of the formats. Almost (another post) everything else plays.
So why wouldn't my player play FLV and WMV thru TsMuxer?
Attached is my config.
TsMuxer confusion
TsMuxer confusion
- 0107_1115.png (86.11 KiB) Viewed 9246 times
Re: TsMuxer confusion
Test transcoding is successful?aVe wrote: Looking at the trans-coding chart, TsMuxer is supposed to process FLV and WMV if I understand it correctly but on my Sony-S570 TsMuxer does not play WMV or FLV. I have to use various other profiles that clearly don't do as good a job as TsMuxer does with the rest of the formats. Almost (another post) everything else plays.
They appear to...
- 0107_1645.png (34.32 KiB) Viewed 9235 times
- flv.png (11.18 KiB) Viewed 9235 times
- wmv.png (11.95 KiB) Viewed 9235 times
BTW: The Sony gives me " There is no playable file "
I recommend using the default settings "Sony BDP-S370/S470/S570/S770 (DLNA, 16:9, 720x406)"aVe wrote:BTW: The Sony gives me " There is no playable file "
