Movie playing time
maybury
Movie playing time
Post by maybury »
When I play a transcoding movie it stops after about 17 minutes. Any reason for this?
Re: Movie playing time
maybury wrote: When I play a transcoding movie it stops after about 17 minutes. Any reason for this?
Transcoder - "Codecs, frame" - File format - MPEGTS (MPEG Transport Stream),
Samsung in format MPEG (DVD) read only 1 GB (the size of vob-file)
maybury
Post by maybury »
Movie lasted about 30 minutes this time with the parameters you listed. Actual movie is about 2 hours. The source file is a single vob about 6gb in size.
maybury wrote: Movie lasted about 30 minutes this time with the parameters you listed. Actual movie is about 2 hours. The source file is a single vob about 6gb in size.
With the use of test transcoding, check that the output format mpegts. If the connection is WiFi, then the problem may be associated with this.
maybury
Post by maybury »
Checked output and it is mpegts. I am running over wi-fi between the LCD and the router the PC is wired to the router. Don't seem to have this issue with non-transcode movies.
Is it possible to save a movie that has been "transcoded" for later play back?
The problem that I'm trying to solve is that I can extract a movie into a single vob file that plays back on the Samsung but the aspect is wrong. Using WMS does solve this problem but only when transcoding.
Thanks for your help.
maybury wrote: Checked output and it is mpegts. I am running over wi-fi between the LCD and the router the PC is wired to the router. Don't seem to have this issue with non-transcode movies.
Setting pre-transcoding http://www.wildmediaserver.com/forum/vi ... p=187#p187
maybury wrote: The problem that I'm trying to solve is that I can extract a movie into a single vob file that plays back on the Samsung but the aspect is wrong.
Are you sure that playing more than 1 GB ?
maybury
Post by maybury »
I'm way out of my depth now! I really have no idea how to do what you are asking me to try. Sorry.
I'll try the same vob file that seemed to time out with WMS on the Samsung server and see if I get the same timing problem.
Thanks again.
maybury
Post by maybury »
Managed to make the changes you suggested. Hit shift 3 and got an error message about not having an input directory specified. Put an input directory in and hit shift 3 but nothing happened as far as I can see.
What should I be doing once I have implimented the changes?
Cheers.
maybury wrote: Managed to make the changes you suggested. Hit shift 3 and got an error message about not having an input directory specified. Put an input directory in and hit shift 3 but nothing happened as far as I can see.
Use Pre transcoding (file), not Pre transcoding (directory). Add the directory Pre transcoding files to the list of directories media resources, to avoid losing files after scanning.
maybury
Post by maybury »
Made the correct changes and it works really well, produces exactly what I want, thanks.
Is it possible to select a specific audio stream like DTS 5.1 or Dolby 5.1?
Can you transcode just the main movie direct from a DVD?
Cheers.
