Hi there my friends!
Congrats for excellent software!
I see two subtitles: one with font that i set on Wild Media Server and the standard subtitles with white color at the same time! I can remove the first one but i prefer it. How i can remove the standard subtitles?
Im searching about this at some days but no solution.
Thank you!
Regards
Samsung UE46C7000 - Double Subtitles using WMS
Re: Samsung UE46C7000 - Double Subtitles using WMS
I think using remote control, according to the User's Manualxdrop wrote: I see two subtitles: one with font that i set on Wild Media Server and the standard subtitles with white color at the same time! I can remove the first one but i prefer it. How i can remove the standard subtitles?
No! the problem was the service "Windows Media Player Network Sharing Service" (i had to disable it) and set some settings in WMS like "select track" and Transcode --> Subtitles tab ---> Use external ass/ssa. Now its ok.
I have this same problem with transcoding. I tried disabling the service and setting to use external ass\ssa for subtitles, and it's still not working. I either see double subtitles, or only the small one or neither. It's usually the first (double subtitles). The problem is "solved" if I don't start the video from the beggining, but then I lose a minute of video...
So, for me, the questio remains: how do I increase subtitles size without losing a minute of video or seeing double subtitles? Thanks!
