Page 1 of 2
DVR-MS and WTV formats HELP
Posted: Thu May 20, 2010 1:37 pm
by winsox
HI
I wonder if you can help me with transcoding these files so I can stream them to a DNLA device.
I used this format on central storage so my "Media Center machines" Vista + windows 7 can record to it , so I have a large libary of these and so far I havent been able to play them back.
I can do it Via Windows 7 trancoding but not via WMS.
Any help would be a great help !!
Dave
Re: DVR-MS and WTV formats HELP
Posted: Thu May 20, 2010 2:01 pm
winsox wrote: I wonder if you can help me with transcoding these files so I can stream them to a DNLA device.
http://www.wildmediaserver.com/forum/vi ... ?f=3&t=274
Quick fix for audio transcoding
Find code
    if WmsCreateDualPipe(sReadVideoPipeName, sWriteVideoPipeName) and
       WmsCreateDualPipe(sReadAudioPipeName, sWriteAudioPipeName) then begin
replace on
    if WmsCreateDualPipe(sReadVideoPipeName, sWriteVideoPipeName, 10000000) and
       WmsCreateDualPipe(sReadAudioPipeName, sWriteAudioPipeName, 10000000) then begin
Find code
      if False and not SameAudioCodec(cfgTranscodingAudioCodec, sAudioTrack) and
         WmsCreateDualPipe(sReadAudioTranscodedPipeName, sWriteAudioTranscodedPipeName) then begin
replace on
      if not SameAudioCodec(cfgTranscodingAudioCodec, sAudioTrack) and
         WmsCreateDualPipe(sReadAudioTranscodedPipeName, sWriteAudioTranscodedPipeName, 10000000) then begin
Posted: Thu May 20, 2010 2:43 pm
by winsox
hi
I added the WTV cfg file and it found the WTV files but still wont play them also trancode failed. Im using windows 7 Ultimate 64
Posted: Thu May 20, 2010 2:51 pm
winsox wrote:hi
If you upload the sample files to rapidshare.com, I will be able to test them.
Posted: Thu May 20, 2010 3:12 pm
by winsox
Posted: Thu May 20, 2010 3:25 pm
My actions
On the right mouse button to select the transcoding profile "Movies - DirectShow - WTV" - Test Transcoding - no problem.
Posted: Thu May 20, 2010 4:12 pm
by winsox
many thanks Test transcode now works but still cant play on Toshiba TV. Is there an easy step by step guide for setting this up ?
This Toshiba only had Mpg, mp3 and jpeg built in codecs.
Many Thanks
Dave
Posted: Thu May 20, 2010 4:56 pm
winsox wrote:many thanks Test transcode now works but still cant play on Toshiba TV. Is there an easy step by step guide for setting this up ?
Try "Movies - DirectShow - WTV (MPEG-PS)"
wtv_mpegps.zip
(1.79 KiB) Downloaded 998 times
Posted: Thu Dec 23, 2010 2:49 pm
Posted: Mon Feb 28, 2011 9:50 pm
by wouter
I am having trouble getting DVR-MS files to transcode. I use the Movies-DirectShow-WTV(MPEG-TS) profile, with extension/file-type set to mpg. In the command window that opens when I try a test I get:
[mpeg2video @ 0026caa0] mpeg_decode_postinit() failure
Last message repeated 2 times
[asf @ 00269c40] max_analyze_duration reached
end then in the end I get:
Codec type mismatch for mapping #0.1 -> #0.0
Help would be appreciated. I am using the latest build.
