k10ck3r wrote:Interesting. So, do I just need to rebuild the database from scratch, or is there a way to force the file properties to update?
"Select All" & "Load file properties" - simplest solutionk10ck3r wrote:Ok, I couldn't find any easy way to force a rebuild, so I went to all music, pressed CTL+A to select all, then did a load properties from file. That seemed to fix it.k10ck3r wrote:Interesting. So, do I just need to rebuild the database from scratch, or is there a way to force the file properties to update?
Is there an easier way to force a rebuild? Did I miss something?
