videos's stutter and more - and no idea what i am doing
Posted: Wed Apr 21, 2010 6:37 pm
Hi Eugene
Thanks for getting my Bravia 32EX503 networked where tversity and WMP11 failed!
Lovely to see my pics and watch the one AVI file I down loaded so far.
Apologies also I have read lots of threads and understand very little about any of it or how it works, certainly the lingo or instructions given in many threads, like the profiles, codecs, transcodes, pastes of computor code, streaming, podcasts etc
so my questions are hopefully simple.
TV to router is cat6 ethernet, router to PC is wireless 802.11G. PC is very old and slow (maxed motherboard with 512MB RAM!)
WMS set up is out the box, latest version on the website. Device set to 1920x1080 Sony TV DLNA 1.5
1. When I play .MOV files (taken on Olympus camera, and play ok in WMP or quicktime on my PC), they stutter and pause on the TV. Maybe while they buffer? Can I change setting to make it play more smoothly. Do I need to set something to convert them for the TV. What boxes do I set and to what.
2. The AVI movie also had a few pauses, but less so. If I rewind a bit then play again, it goes on further, like it has had time to send more of the file to the TV? As above is this settings.
3. Will WMS play music on a random shuffle from a group of selected folders? How do you set this up?
4. I believe I can view BBC iplayer and other similar sites. I see there is something in one thread to download. Once done where do I drag the file specified to (I did not understand the answer). The how to I play an iplayer etc video on TV (ones not available to download). Do I have to play it in my web browser and run to the TV and select something? or will WMS contol the start/stop via the TV selecting a folder?
5. Finally, when I first connect, all was ok with IP address etc. Yesterday it woudl not start the server or the TV see the server - turns out the IP addresses had changed, gone up 1 so I just changed them and deleted the 'old' server on the TV. Could be as there were 2 PC's on my wireless then? Can you set fixed IP addresses or is that in the router? Perhaps set the PC to be fixed (for the TV's setting benefit) and the server to accept any IP address on that device? If so how, I have no idea.
Sorry to ask so much, maybe the simple things will help many other non tech users, to scared to try WMS with all the technical settings and phrases.
