Just downloaded Wild Media 0.73. Did not find if there is a way to stream grooveshark to my LG TV via DLNA?
Any way to do this? Any plans for this type of support?
Thank you
Example link ?nextbond wrote:Hi,
HI there,Eugene wrote:Hi,Example link ?nextbond wrote:Hi,
http://akamai.grooveshark.com/73/221800 ... 3bc4845a98 - added to Internet-radio, no problem.nextbond wrote:HI there,Eugene wrote:Hi,Example link ?nextbond wrote:Hi,
http://listen.grooveshark.com
If this supported VLC.nextbond wrote: Also can WMS stream whats coming out of the PC soundcard to the DLNA device?
I do not know, I tried it first it works. If you specify a link that does not work, I can check it.nextbond wrote:Is the akamai.grooveshark.com.... link work to stream a particular song from grooveshark or any song you play in your browser on grooveshark?
To me offered this link to download my Download Manager, when I chose the song.nextbond wrote: Did it work for multiple songs on grooveshark or just one of them?
The akamai.grooveshark.com link.../18213457.mp3... link you tried may indicate a single song since it has the ".mp3" in it.
How did you come upon/derive this akamai based link of grooveshark?
1. Install VLC (http://www.videolan.org)nextbond wrote:I added this as an Internet Radio link.
But when I try to play it on my DLNA enabled TV, it says network error. Other music stored on my laptop plays just fine via DLNA.
Am i setting this up incorrectly in Wild Meda Server on my laptop?
Any advice?
