Is it possible create 'translate profile'
Transcode is change or recode codec X to codec Y this is loosing CPU power and quality
in my meanning translate is only use VLC/mplayer/mencoder
dump shoutcast stream and create output in suitable file format without
transcoding
example mencoder -ovc copy -oac copy -of [mpeg or mp4] ... tml]source
when is based on ffmpeg there is acodec option also copy
is it possible use aenc=copy for this ?
WDTV translate profile
Re: WDTV translate profile
Media resource type: Music
Mime-type: video/mpegts
Transcoding parameters:
Choose a new profile for a media resource on the right mouse button. By default transcoding buffer for internet resources is not used (size = 0). Settings-Transcoder-Buffer-Internet
Another profile
Mime-type: audio/x-wav
Settings-Transcoder-Profiles-Addkm123 wrote: Is it possible create 'translate profile'
transcoding
"<VLC>" -Idummy --language=en --sout=#duplicate{dst=std{access=file,mux=ts,dst="<OUTPUT FILE>"}} "<INPUT FILE>"
Another profile
"<VLC>" -Idummy --language en --sout=#transcode{acodec=s16le,samplerate=44100}:duplicate{dst=std{access=file,mux=wav,dst="<OUTPUT FILE>"}} "<INPUT FILE>"Re: WDTV translate profile
this is not working for me now - vlc syntax is ok (Audio - remux profile)
VLC executed from cli is working but WDTVlive is not playing i-radio
only busy rotating cursor is on TV
update on 0.73.4 version
but oroginal Music VLC -> WAV is producing this error
VLC- error log
File reading failed:
VLC could not open the file "Code:".
Your input can't be opened:
VLC is unable to open the MRL 'Code:'. Check the log for details.
VLC could not open the file "E:\tmp\WmsTemp\Test_d2043da22032f15de979796021f70da4.wav".
VLC is unable to open the MRL 'E:\tmp\WmsTemp\Test_d2043da22032f15de979796021f70da4.wav'. Check the log for details.
VLC- error log
"\Program Files\VideoLAN\VLC\vlc.exe" Code: "E:\tmp\WmsTemp\Test_d2043da22032f
"\Program Files\Wild Media Server\wmsmpeg.exe" "D:\Program Files\VLCPortable\A
pp\vlc\vlc.exe" -Idummy --language en --sout=#transcode{acodec=s16le,samplerate=
44100}:duplicate{dst=std{access=file,mux=wav,dst="E:\tmp\WmsTemp\Test_d2043da220
32f15de979796021f70da4.wav"}} "http://94.23.8.96:8030"
I have no problems at WDTV Live with profile
Perhaps you have a problem because of the use VLC Portable
"<VLC>" -Idummy --language en --sout=#transcode{acodec=s16le,samplerate=44100}:duplicate{dst=std{access=file,mux=wav,dst="<OUTPUT FILE>"}} "<INPUT FILE>"Perhaps you have a problem because of the use VLC Portable
no VLCportable is removed and installed normal 1.0.5 Goldeneye VLC player
I am using last fw in WDTVlive player
if is possible add to "how to use WMS" also Music documentation
what is minetype (I know what is) but how minetype affecting playback
changing filename extension or minetype is part of XML packet which is sent to player
WDTV live is not using "file/magic" filetype for detection wrong
filename extension and supported codec in supported container is sometime problem
