Podcasts Gallery
JohnCSS
Re: Podcasts Gallery
Post by JohnCSS »
Hi Eugene.
SeeSaw is now online.
http://www.seesaw.com/top-100
Will it be possible to create a podcast script for this?
John G
redpixel
Post by redpixel »
Is it possible to create an script for this "standard" rss.
http://www.tv3.cat/3alacarta/podcast/xml/crackovia.xml
I'm able to download it with wms but I cannot manage to sent it to my TV....
Thanks in advance.
Redpixel
redpixel wrote: Is it possible to create an script for this "standard" rss.
Not very good, but still the decision
Podcast "Crackòvia" - right click - Edit title - "Script for the links to the resource" - On - "Edit Script"
Language: PascalScript
Expression:
  MediaResourceLink := '"' + mpFilePath + '"'
New version ITV Player (with subfolders) http://www.wildmediaserver.com/forum/vi ... 3117#p3117
Australian MSN Video (http://video.au.msn.com/browse/tv-shows/genres) (required version 1.10)
aumsn.zip
(6.12 KiB) Downloaded 2522 times
2. Drag and drop aumsn.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear Australian MSN Video. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file aumsn.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder Australian MSN Video, you can update the list of podcasts.
Updated 2011/04/02
Updated 2011/08/08
JohnCSS
Post by JohnCSS »
The new ITV Player is brilliant, Eugene - ALL content shows automatically! Thanks.
Also, I don't have problem with SeeSaw - content there also shows and is stable (Maybe best in UK only . . ?)
You might want to look at Five Demand now - Due online start of November, but here in beta .... http://beta.five.tv/watch
Thanks for all thus far - Superb program - Best on the Net.
John G
Australian Yahoo!7TV (http://au.tv.yahoo.com/plus7/browse/) (required version 1.05.1)
auyahoo.zip
(7.37 KiB) Downloaded 2555 times
2. Drag and drop auyahoo.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear Australian Yahoo!7TV. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file auyahoo.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder Australian Yahoo!7TV, you can update the list of podcasts.
Updated 2011/04/02
Required version 1.51
Australian Channel Ten (http://ten.com.au/)
auten.zip
(12.4 KiB) Downloaded 2289 times
2. Drag and drop auten.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear Australian Channel Ten. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file auten.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder Australian Channel Ten, you can update the list of podcasts.
Updated 2011/04/02
Updated 2011/08/08
Updated 2012/05/22 (added support for the mode "The script generates a few links (the call while navigating on the device)")
Australian ABC iView (http://www.abc.net.au/iview/)
auiview.zip
(3.24 KiB) Downloaded 2648 times
2. Drag and drop auiview.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear Australian ABC iView. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file auiview.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder Australian ABC iView, you can update the list of podcasts.
Updated 2011/01/02
Updated 2011/02/01 (thanks to the user GreenEx)
Updated 2011/04/02
alarma
Post by alarma »
Eugene, could you build this one, please? Sexta TV - Program TV "Salvados" http://www.lasexta.com/sextatv/salvados.
Do you have any tutorial to do this work?
