Released version "Wild Media Server (DLNA) v2.73
Posted: Thu Jun 09, 2016 2:21 pm
Update to 2.73 (x32) (2.59-2.73)
Update to 2.73 (x64) (2.59-2.73)
Wild Media Server (UPnP, DLNA, HTTP) v.2.73
1. Settings - Media resources - Service - Folder "Transcoding" - Audio streams:
4. Scripts:
- added setting "Volume level".
- Transcoding - Movie Folder - Settings:
- added selection of volume level at transcoding;
- added selection of DVD aspect ratio (when you select 16:9, upper and lower parts of frame are cropped).
4. Scripts:
- added functions WmsLoadMediaItemFromFile, WmsLoadMediaItemFromUrl, WmsSaveMediaItemToFile, can be used to save/load description of media resources in the wdf format (xml) and supported playlists (load only), description of media resources can be in the zip archive.
- added setting "Scale forms".
