CWTV - Shows (http://www.cwtv.com/shows/)
CWTV - Shows (http://www.cwtv.com/shows/) - required version 1.77
cwtv_shows.zip
(2.89 KiB) Downloaded 1649 times
2. Drag and drop cwtv_shows.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "CWTV - Shows". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file cwtv_shows.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "CWTV - Shows", you can create first level of "CWTV - Shows" navigation.
Additional parameters - select the folder "CWTV - Shows" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
:!: Thumbnails available in the United States only :!:
