Syfy - Shows (http://www.syfy.com)
Syfy - Shows (http://www.syfy.com) - required version 1.77
syfy.zip
(4.07 KiB) Downloaded 1985 times
2. Drag and drop syfy.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "Syfy - Shows". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file syfy.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "Syfy - Shows", you can create first level of "Syfy - Shows" navigation.
Additional parameters - select the folder "Syfy - Shows" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
Subtitles support:
--subtitles=on
Maximum video height:
--maxheight=NNN
