Gametrailers.com (http://www.gametrailers.com)
Posted: Tue Jun 11, 2013 11:34 am
Gametrailers.com (http://www.gametrailers.com) - required version 1.77
Gametrailers.zip
(4.9 KiB) Downloaded 1061 times
2. Drag and drop Gametrailers.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "Gametrailers.com". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file Gametrailers.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "Gametrailers.com", you can create or update first level of Gametrailers.com navigation.
Additional parameters - select the folder "Gametrailers.com" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
Page count of videos (by default 10):
--pagecount=NN
