TheStreamDB.com (http://thestreamdb.com)
Posted: Tue Jun 11, 2013 9:05 am
TheStreamDB.com (http://thestreamdb.com) - an open database for public access streaming media, required version 1.77
thestreamdb.zip
(2.94 KiB) Downloaded 1080 times
2. Drag and drop thestreamdb.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "TheStreamDB.com". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file thestreamdb.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "TheStreamDB.com", you can create or update first level of TheStreamDB.com navigation.
:!: Part of the channel requires installation VLC Media Player (http://www.videolan.org)
