ARD MediaThek (http://www.ardmediathek.de/fernsehen)
Posted: Mon Jun 10, 2013 3:32 pm
ARD MediaThek (http://www.ardmediathek.de/fernsehen) - required version 1.77
ardmediathek.zip
(5.56 KiB) Downloaded 1645 times
2. Drag and drop ardmediathek.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "ARD MediaThek". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file ardmediathek.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "ARD MediaThek", you can create or update first level of ARD MediaThek navigation.
Additional parameters - select the folder "ARD MediaThek" - right click - Edit title/settings - Transfer - Additional parameters
Subtitles support:
--subtitles=on
Page count of videos (by default 10):
--pagecount=NN
Updated 2014/03/07
Re: ARD MediaThek (http://www.ardmediathek.de/fernsehen)
Posted: Fri Mar 07, 2014 5:00 pm
Updated 2014/03/07
