Animal Planet (http://animal.discovery.com/)
Posted: Wed Jun 05, 2013 10:59 am
Animal Planet (http://animal.discovery.com/) - required version 1.77
animalplanet.zip
(6.07 KiB) Downloaded 1469 times
2. Drag and drop animalplanet.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "Animal Planet". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file animalplanet.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "Animal Planet", you can create or update first level of Animal Planet navigation.
Additional parameters - select the folder "Animal Planet" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
Video count (by default 25):
--videocount=NN
Subtitles support:
--subtitles=on
Updated 2014/03/07
Re: Animal Planet (http://animal.discovery.com/)
Posted: Thu Oct 24, 2013 1:23 pm
Updated
Posted: Fri Mar 07, 2014 5:39 am
Updated 2014/03/07
