ABC - Shows (http://watchabc.go.com/shows)
Posted: Tue Jun 04, 2013 8:56 am
ABC - Shows (http://watchabc.go.com/shows) - required version 1.77.1 (64-bit) | 1.77.1 (32-bit)
abcshows.zip
(4.83 KiB) Downloaded 1612 times
2. Drag and drop abcshows.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "ABC - Shows". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file abcshows.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "ABC - Shows", you can create or update first level of "ABC - Shows" navigation.
Additional parameters - select the folder "ABC - Shows" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
Subtitles support:
--subtitles=on
Maximum video height:
--maxheight=NNN
Updated 2014/03/01
Re: ABC - Shows (http://watchabc.go.com/shows)
Posted: Sat Mar 01, 2014 5:34 am
Updated 2014/03/01 (adds --maxheight)
