TOU.TV (http://www.tou.tv)
TOU.TV (http://www.tou.tv) - required version 1.77
toutv.zip
(4.38 KiB) Downloaded 1760 times
2. Drag and drop toutv.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "TOU.TV". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file toutv.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "TOU.TV", you can create or update first level of TOU.TV navigation.
Additional parameters - select the folder "TOU.TV" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
:!: Service only available in the North America :!:
Updated 2014/03/26
Re: TOU.TV (http://www.tou.tv)
Updated 2014/03/26
