CBS Sports (http://www.cbssports.com)
Posted: Sun May 26, 2013 7:55 pm
CBS Sports (http://www.cbssports.com) - required version 1.77
cbssports.zip
(4.66 KiB) Downloaded 872 times
2. Drag and drop cbssports.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "CBS Sports". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file cbssports.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "CBS Sports", you can create or update first level of CBS Sports navigation.
Additional parameters - select the folder "CBS Sports" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
Subtitles support:
--subtitles=on
