BBC iPlayer (http://www.bbc.co.uk/iplayer)
BBC iPlayer (http://www.bbc.co.uk/iplayer) - required version 1.77
BBC iplayer.zip
(7.97 KiB) Downloaded 807 times
2. Drag and drop BBC iplayer.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "BBC iPlayer". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file BBC iplayer.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "BBC iPlayer", you can create first level of BBC iPlayer navigation.
:!: Service only available in the United Kingdom :!:
Additional parameters - select the folder "BBC iPlayer" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
Subtitles support:
--subtitles=on
