ITV Player (https://www.itv.com/itvplayer/)
ITV Player (https://www.itv.com/itvplayer/) - required version 1.77
itvplayer.zip
(8.13 KiB) Downloaded 943 times
2. Drag and drop itvplayer.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "ITV Player". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file itvplayer.wdf by right click in the folder tree.
By the right mouse button in the folder tree on the folder "ITV Player", you can create first level of ITV Player navigation (update your rentals and the folder "By day").
:!: Service only available in the United Kingdom :!:
ITV Player login: select the folder "ITV Player" - right click - Edit title/settings - Connection - Authorization - On - UserName: your ITV Player login, Password: yout ITV Player password.
Additional parameters - select the folder "ITV Player" - right click - Edit title/settings - Transfer - Additional parameters
--mutibitrate=on
Subtitles support:
--subtitles=on
