Channel4 - PS3 (http://ps3.channel4.com/)
Channel4 - PS3 (http://ps3.channel4.com/) - required version 1.77
channel4_ps3.zip
(202.39 KiB) Downloaded 852 times
2. Drag and drop channel4_ps3.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "Channel4.com (PS3)". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file channel4_ps3.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "Channel4.com (PS3)", you can update the list of podcasts.
:!: Service only available in the United Kingdom :!:
Subtitles support: select the folder "Channel4.com (PS3)" - Edit title/settings - Transfer - "Additional parameters" -
--subtitles=on
