Error Message: Out of memory
Helios61
Post by Helios61 »
Hi Eugene!
If i try to scan my music directoties, i allways get the error message "out of memory"! I am using WMS 0.73 on WinHP/32! Scanning the movie directories is working fine!
Could you please help?
Best regards
H
Re: Error Message: Out of memory
Helios61 wrote: If i try to scan my music directoties, i allways get the error message "out of memory"! I am using WMS 0.73 on WinHP/32! Scanning the movie directories is working fine!
Settings-Media-resources-Scanning-turn off "Read properties of new files". In the list of music files on the right-button mouse, you can read the file properties, find the problem file.
Helios61
Post by Helios61 »
Eugene wrote:Hi,
> 20.000 files :roll: Isn't there another way to find the problem file?
Helios61 wrote:
Eugene wrote:Hi,
Settings-Media-resources-Scanning-turn off "Read properties of new files" - solves the problem?
Helios61
Post by Helios61 »
Helios61 wrote:
Eugene wrote:Hi,
Yes it does! Maybe there is a wrong cuesheet inside the directory! Most of my music i have stored as lossless image with cuesheet!
Another issue with scanning a folder! I get this error message:
Best regards
H
Helios61 wrote: Maybe there is a wrong cuesheet inside the directory! Most of my music i have stored as lossless image with cuesheet!
Properties can be read for the currently selected in the list of files.
Helios61 wrote: Another issue with scanning a folder! I get this error message:
If possible, please compress all the ifo-files (from VIDEO_TS) in the archive and attach to the forum or send to support@wildmediaserver.com. Although the problem may be with the vob-files.
Helios61
Post by Helios61 »
Thanks for reply, eugene! .ifo's are attached!
Best regards
Helios
VIDEO_TS.rar
(3.41 KiB) Downloaded 708 times
Helios61 wrote:Thanks for reply, eugene! .ifo's are attached!
vts_03_0.ifo, vts_04_0.ifo, vts_05_0.ifo - empty
If you use in directories of media resources working directories file-sharing networks, it is bad.
